17" cup wheels value
I ordered a new set of wheels and will want to sell my wheels when they come in.I don't know the value of my old ones however.
17" Mille Miglia cup replicas
perfect shape,no curbs,scratches or chips
The only flaw I can find on them is some slight discloration around the valve stems,I don't know what causes this.A small ring around the stem.
I think they are 8s and 9s,but can measure to be sure.
I am not out to rob anyone and would love someone local to Hilton Head Island,SC if possible so I don't have to ship.
Are they worth $50-$100 each?
Old 09-30-2009, 04:03 PM
gpotts200's Avatar
Are they being sold with the tires on? If so, what tire model, size and how much remaining tread. What offset are they?
1984 Guards Red Porsche 944 NA
2005 Suzuki Forenza
2005 Suzuki SV650 **SOLD**
2008 Toyota Siena
Old 09-30-2009, 04:15 PM
flash968's Avatar
replicas of C2 Turbo wheels (the correct name for them) like those should be good for at least $500 for the set if they are flawless - new was about $1100 the last time i checked (a couple of years ago)
they should say on the inside what size and ET they are (use a mirror)
depending on what sizes and ETs they are, there should be a good market for them - i ran them on one of my 968s for a while - worked great
Old 09-30-2009, 04:17 PM
I am switching the tires to the new wheels as they have less than 2000 miles on them.
The wheels are late offset that fit 87 and up.
Old 09-30-2009, 04:19 PM
Thanks,I will try the mirror and see what I can find
Old 09-30-2009, 04:21 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Porsche Crest That Should be a Steal...
I would think that they are worth more than that. I just but winter steel rim at Costco for a Civic @ $50.
I'll track your thread as I would like more info on the Cup wheel in general.
Who Will Live... Will See
Old 09-30-2009, 04:25 PM
flash968's Avatar
they could be worth more, but they are replicas, which are a couple of pounds heavier than the real ones, and different offsets, so it could take the "right" guy to get more
but to answer the question, yes, they are definitely worth at least $100 each
Old 09-30-2009, 04:33 PM
racer's Avatar
You can find genuine Cup1 (Turbo) wheels in the $600-800/set without tires. I would think replicas shouldn't be worth more than 1/2 of that.
Also, what year (offset) are they? the "et23" range (ie early offset) or "et52" range (late offset)?
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 09-30-2009, 04:50 PM
I just came from the garage and did the mirror trick and the best I can tell I read
front 052 which I assume is a 52 offset
rear I see :
054 54 offset sound right?
R10 ( 10 inch?)
CUP1
Made in Italy on both front and rear
Old 09-30-2009, 04:52 PM
racer's Avatar
they are most likely 7 or 7.5" wide on front and 9" on the rear.
Past:
Old 09-30-2009, 05:22 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
I've got a set of replicas (Borbet) that are 7-1/2" front, 9" rear that I'm willing to sell for $300 (no tires). I was actually going to throw them on FeeBay tonight (I need 'em gone). If you're interested let me know.
Black Cars Matter
Old 09-30-2009, 05:26 PM
BTW I love that yellow 944. I'm in the process of prepping my 944 for paint right now (probably going with a very similar color). Just thought I'd mention. I actually like how the Cup wheels look on it, but I think I'm still going to sell 'em and keep my BBS RSes.
Black Cars Matter
Old 09-30-2009, 05:27 PM
Thanks,the color is Summer Yellow available on the 944 in 87 only and on 911s in 87 and maybe a few other years.
I like the Cup wheels also,but my favorites on a 944 has always been the Fuchs and when the opportunity came up to get some custom made Jeff Alton Fuchs in 17 inch 8 and 9s with the correct late offset,I decided that was what I really prefer.
Old 09-30-2009, 06:03 PM
flash968's Avatar
genuine C2 Turbo wheels (often misnomered as Cup 1) usually go for about $1000 if they are clean and 7.5" front and 9" rear - beat up ones go for less - 7" go for less - 9.5" and 8" go for more
real "Cup" wheels, which only came on the european cup cars, are magnesium and go for a LOT more
Old 09-30-2009, 06:07 PM
They are definately not genuine Porsche wheels,they are replicas,but Cup 1 is cast into the back of the wheels.I am not sure what they are replicas of,C2 Turbo or Cup 1s.I do not know the difference.
They may be 7.5s and 9s.Is there an accurate way to measure when the tires are mounted?
Old 09-30-2009, 06:17 PM
flash968's Avatar
since there never was any wheel called Cup 1 by porsche (or Cup 2 for that matter), that one is easy - those are C2 Turbo
people have been calling them by the wrong names for years
the whole "Cup 1 Cup 2" thing was a european misnomer that started when the first wheels that "looked" like the wheels that came on the Cup car came out on the 911 - they were very different though, no matter how similar looking they were - then when the next one came out, those same people continued that error and called it Cup 2 - in reality those were called "993 Cup" - the other names never came from porsche though
consult wheel enhancement for further info - they are the only authorized non-dealership full retailer for porsche wheels in the country - they get their documentation directly from porsche
they should be marked on the back, but if you want to measure them, you measure between the insides of the lips - if the tires are mounted, you can measure the outside, and subtract 1" and round to the nearest 1/2"
Old 09-30-2009, 06:39 PM
Thanks for the info.
I measured with the tires mounted and hooked a tape measure on the inside of the wheel and measured to the outside edge and get 81/2 front and 10 inch rear.So I guess that makes them 71/2 and 9s.
Old 09-30-2009, 06:49 PM
flash968's Avatar
sounds right - shouldn't be hard to sell at all
Old 09-30-2009, 07:18 PM
Damian in NJ's Avatar
Those Cup 1's look nice with the yellow.
95 968 Cab, Speed Yellow, Kinesis Supercups, Promax chip, Big Reds, SS brake lines, 5/35 brake bias valve, H&R sport springs, mo30 sway bars, LSD, Brey Krause control arm brace, Dynatech billet strut brace, Cargraphic 100 cell cat and ss exhaust, Club Sport steering wheel, short shift, sport seats
Old 10-07-2009, 05:46 AM
white944cup's Avatar
Jsteve340: How about some pic's of your new wheels.....they should be awesome!!!
1988 944 Turbo
Guards Red - Black Leather
Autothority Stage 2 Chip Set
Weltmeister Strut Tower Brace
1984 944 - Sold to rcecale
Old 10-07-2009, 09:22 AM
