Feelin' Solexy
Tishabet's Avatar
Why does my car seem to run better with a full tank?
After years of telling myself I'm imagining things, I've finally concluded that my car really and truly runs better/smoother when I have a full tank of gas. The thing is, I can't figure out what difference it should make... but idle in particular is smoother if I've just topped off. Any thoughts or similar experiences?
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 11-19-2009, 02:37 PM
mistertate's Avatar
The fuel pump is at the bottom of the tank. There's more pressure at the bottom of a 20,000 league ocean than a 1 league ocean. Maybe there's something restricting fuel pressure? A fuel filter maybe?
dude
Old 11-19-2009, 03:11 PM
placebo effect?
is it the full tank? or the act of refuelling?
what if u just filled up 1/4 tank?
Old 11-19-2009, 03:40 PM
Feelin' Solexy
Tishabet's Avatar
Originally Posted by krystar View Post
placebo effect?
I chocked it up to placebo effect for the last 5 years, but recently I've had a heat shield that has started rattling underneath the car a bit at idle. I've noted that the car doesn't just "feel" smoother at idle (which I would have figured was placebo) but that when the tank has just been filled, the heat shield rattles much less.
I suppose you could say the car is sitting lower on the suspension and the vibrations are lessened by the extra mass of the gas to absorb it.... but it really does feel like it is running better.
Grant
Old 11-19-2009, 03:56 PM
maybe something to do with tank vent pressure? what if u just open up the gas cap and vent it? any diff?
Old 11-19-2009, 04:38 PM
Proprietoristicly Refined
John_AZ's Avatar
More fuel getting past the fuel screen in the tank?
Mine had cuts, straw, bugs, tank slime on the screen
GL
John_AZ
Old 11-19-2009, 04:52 PM
All Spooled Up
Try checking the FPR and the damper diaphragms. Pull the vac lines off and see if you can smell fuel in them.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 11-19-2009, 05:01 PM
your average wrencher...
more weight in the ass end=more grip for the rear wheels!!! may just be smoother on the powerband.
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 11-19-2009, 05:28 PM
Send a message via AIM to ike229
Ive always felt this way too.. Both in my 924S, and motorcycle.
Always feels good to fuel up.
'05 M3 - Alpine White
'88 924S - Black
'91 318IS - Alpine White
'88 Honda Hawk
'75 Honda CB360
Old 11-19-2009, 06:16 PM
Cars & Coffee Killer
legion's Avatar
A league is a measure of distance. A fathom is a measure of depth.
5 liters of VVT fury now
-Chris
Old 11-19-2009, 07:41 PM
Send a message via AIM to Lapponia
+1 John Tate and John_Z. Did you look at the FP filter in my thread "Death of a fuel Pump"? There you can see 25 yrs of filter duty but only if you crack open the pump e.g. destroying it. FP is bad all the same and should be exchanged. I guess what John T said about pressure on ocean bottom, sure there is a bit more pressure out of fuel tank when full (pillar height of fuel in tank times fuel density). I would reccomend you to change your FP if 20++ yrs. car will run so much better.
Good luck. Lapponia
Old 11-20-2009, 05:16 AM
