how do i remove seats?
Ok, this might be a dumb question. How do i remove the seats in my 1988 944. i stripped all the carpet and rear seats already. I also removed the backs to the seats now i have the seat bottoms on the rails. Do i use a alan wrench? Please help!
1988 Satin Black Metalic , Plaid interior 944 "Celebration Edition" Sold and now autocrossed in canada
1985.5 Guards Red 944na 66,000 miles (SOLD in 2002 )
http://porsche944celebrationedition.weebly.com/
Old 11-17-2009, 08:09 PM
Slide them all the way back and you should see some allen head bolts in the track... Then slide it all the way forwards and you should see some more.
Old 11-17-2009, 08:27 PM
Misunderstood User
Mine had hex head screws. Use 1/4 drive ratchet w/ the appropriate socket.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 11-18-2009, 03:00 AM
cwiert's Avatar
my '88 has hex head screws too. you need the right bit. an alan wrench will only strip it and then you'll have yourself a real problem.
btw - just to remove the seats, you didn't need to do all that other stuff like remove the upper part of the seat and the carpet. the seats will come out in one piece. remember to disconnect the wiring harness (for power seats) under the seat bottom.
'88 Porsche 928 S4 - LSD - Sold
'88 Porsche 944 N/A - Sold
Old 11-18-2009, 04:20 AM
Just to clarify, when you move it all the way back, you can see the allen bolts in *front* of the seat, then move it forward and you will see the ones in the rear.
Old 11-18-2009, 08:08 AM
Back from Beyond
When reinstalling it helps to take a screwdriver and make sure all the trapped nuts are lined up properly. They strip very easily, and next thing you know you're drilling through the floor and bolting the seats in...
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 11-18-2009, 08:20 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
There are 6 socket head cap screws holding the seats (A few cars had hex head screws - but not many - most were the Allen head cap type). One does have to slide the seats back and forth to access all of the screws. There is the power plug going to the seats that are powered. There is also a small wire that goes to the emergency brake for it's warning light in the dash. This wire almost always gets pulled loose when doing the seats so watch for it so it's not torn up and it's reusable when re-installing the seats.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 11-18-2009, 09:01 AM
Thanks guys!
Old 11-18-2009, 08:59 PM
