CONTROLL (A) ARM refurbish?
i have an 1984 944 with i assume is stock a arms, bushing, and ball joints.
i think i heard that the early came with steel arms. what would be the proper parts list to rebuild the ball joints and bushings?
are the early even rebuildable? if not what would be the recommend path to take? im at the point where the right side basically doesnt even have a bushing in the controll arm. i can see where it was and the rubber is shredded.
Old 11-22-2009, 07:09 PM
That Guy
Techno Duck's Avatar
The arms are rebuildable. You want the rear and front bushings aswell as the balljoints. Total cost of parts per arm will run about $60. If the arm itself is looking beat
(rust) new bare arms are about $25 each.
Old 11-22-2009, 07:19 PM
SO.....they are rebuildable! GREAT!! thats what i like to hear!
i thought someone said they where not.....
i assume rennbays balljoint kit will work wonders!
Old 11-22-2009, 07:21 PM
Its only a vw part...
Old 11-22-2009, 07:48 PM
That Guy
Rennbay's kit only works on the aluminum arms. The steel arms are much more simple and cheap to rebuild.
Old 11-22-2009, 07:56 PM
Hi, A great writeup with pictures on how to rebuild the control arm.
Control Arms - Porsche 951 - www.texasblake.com
Cheers,
Larry
Old 11-22-2009, 08:16 PM
Custom User Title
mikepellegrini's Avatar
The early steel control arms are easy as all get out to do the ball joints - no rebuilding. Just pop a new one in place (for $16.75) and you're on your way.
Porsche 924S/944/968 Suspension - Page 4
The front bushing (if it's that) is about $5.00. I just wish it were the same for the late control arms...
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 11-22-2009, 09:19 PM
far easier than i thought! and cheaper!!
1984 944 - black exterior, black/tan/brown interior (somehow it works....) 100K or so miles
Old 11-22-2009, 09:23 PM
Toofah King Bad
Rasta Monsta's Avatar
Prothane makes a great poly bushing kit that will work. . .look for Rabbit/Golf Mark I.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-22-2009, 09:56 PM
Toofah King Bad
Oh yeah, you might want to have them seam welded and powder coated while they are off. . .
YES, THE REAR BUSH IS ON BACKWARDS IN THIS PIC.
Old 11-23-2009, 10:13 AM
Just thinking out loud
mattdavis11's Avatar
The old bushing (front one) is fun to get out. Be prepared to drill out 3 rivets per arm to remove the ball joint assembly.
91 FJ80
84 Ram Charger (now gone)
Old 11-23-2009, 10:33 AM
ernie9944's Avatar
Did them on mine quiet a fews years back ,melting butter in the frying pan & does it ever make a difference lol,if it's a keeper #1 for Rasta Monsta.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 11-23-2009, 11:01 AM
banana944's Avatar
How the hell do you get the rear bushings off, the single piece one (in Rasta's 2nd pic)? And is the metal sleeve supposed to be removed or not?
I burned one off on a spare arm I had, and I think I ruined it trying to remove what I thought was an inner sleeve in the bushing.
Old 11-23-2009, 06:39 PM
