944 Auto 1988
"Wine" high pitch sound coming from bell housing fire wall area. It changes sound, higher pitch and louder as rpm increases. Makes most noise when trans is downshifting approaching stop. (But only going down road, does not make sound if parked or on jack stands wheels free spinning in gear, running) Ideas?
Lowell 1988 944 Red Project car (Now daily driver, Daughter's to school ride) 1983 944 Grey NEW Project car http://www.pelicanparts.com/gallery/tnporsche |
Nobody Special
Pilot bearing or first TT bearing wearing out? Did you ever have a water hose or heater valve fail? If so, the coolant can damage the pilot bearing.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD 91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD 86 - 951-K26/8, daily driver-SOLD 87 - 944S - Another daily driver-SOLD Last edited by 2Tight; 11-26-2008 at 04:50 AM.. |
are we talking like a merlot or like a shiraz? heh j/k
when was last time the clutch was done? |
Nobody Special
It's an auto.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD 91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD 86 - 951-K26/8, daily driver-SOLD 87 - 944S - Another daily driver-SOLD |
ah n/m. missed that part
maybe the torque tube is on its way out
No left turn un stoned |
I did find that the splash guard was missing at the bell housing, ( did not relalize that) and daughter drove through heavy rain the day it started. We are still driving it but limited, noise is about same as in october, but very anoying. If it is the pilot bearing and it fails completly is there a risk of major damage to other stuff? Or can it wait till the lift gets free? lol (other project currently on lift) and not looking forward to pulling engine again.
update: after motor pull
To recap. 1988 944 NA Auto Trans
Right after a rain a sudden sound starting coming from firewall area. Will NOT make the winning sound if on jack stands. Sound is at all speeds but increases at decelerating. No on the water leak. Well after finally getting around to fixing, and pulling motor (did not go by pulling trans, long story there) anyway same sound is coming from front and center of car. Wasted alot of hours it seems. When motor was out I thought I had found the problem because the pilot shaft bearing had been spinning on the shaft and had worn it down a little. It looks like the pilot bearing was very stiff and caused the spinning. I built up the shaft and put in a new bearing. I also spun, pushed and pulled the shaft, no slack was felt. When I go back in this time I am going through the trans. Even if I have to cut support out, and replace. Any other Ideas.
Dog-faced pony soldier
I've occasionally had the sound of a beer being cracked open from that area, but never a wine.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
funny , wine winne whine wiree werrr warrr wheer . Pick one
Hi, read your post. It could be a torque tube bearing starting to go.
Hi, I doubt you can tell by turning it by hand. The cheapest route would be to throw in a known good used torque tube from someone parting out a car but the best route would be to buy a rebuilt assembly outright if it is indeed the torque tube. Sounds to me like it could be your tube but you will want to take the auto trans out of the equasion for sure. I am not to familiar with auto transaxles to know what they sound like when they are going south.
LOL.
Does anyone know the part number for torque tube bearings? Its listed on pelican as whole tube.
Did you ever sort this out? I may have something similar going on.
der Geist www.themissionboutique.com 03 Boxster, 69 911 i(the eternal project) 04 CLK55 AMG Supercharged!, 04 VW Touareg |
Well, It finally failed!
Sound got very loud and bang stopped pulling. At least now should find problem. I have not pulled the trans out yet its just sitting in drive for now. But I learned that the sound must be reflecting or something to sound like its in middle or firewall. But in fact must have been transaxle. I guess I will pull it out this winter , but being it stopped pulling and it had a bad grinding sound then its gota be the transaxle right?
