Unhappy 1986 VDO Gauges not working!!! HELP!
I recently took out my instrument cluster to change the lights so it would be brighter. After i changed the bulbs I put the instrument cluster back in but it it does not work now. I don't know what happened and it is really frustrating? everything is hooked up and no fuses blew? please help?
Old 12-03-2009, 01:57 PM
Proprietoristicly Refined
John_AZ's Avatar
I hope it is not serious. Did you recheck the grounds up under the dash? Did you reconnect the battery when you took off the cables to begin?
This is from the Tech Info Center ^^ and may help.
The disclaimer is scary.
Pelican Technical Article: Solving Strange 944 Gauge Problems...
GL
John_AZ
Old 12-03-2009, 03:12 PM
Tags
1986 , cluster , gauges , instrument , vdo
