LinkBack | Thread Tools | Rate Thread |
All Spooled Up
Does anyone make a gauge panel for the under-the radio area of the console?
Basically, I'm looking for a black plastic panel that has a rectangular cut-out on top half, for the radio, and 3 (or even 2) round holes in the bottom half that will fit 2" gauges. I'd like to avoid having to make my own, because it probably won't look pretty. Is there any outfit that makes 'em?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
^^Is that what your talking about if so "9xauto,com has them" also believe I,ve seen somthing similar in flash 968 car but not sure.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
All Spooled Up
Yea, kinda. But they are only the bottom half of what I had in mind. I also need about 1/4" of plastic "trim" to go around the radio. Maybe I can work some else out for that. But if I do that, I might as well make the whole thing with gauge cut-outs, 1 piece. The panels you are showing do look pretty nice, though. They kind of remind me of 15" rack-mount components, with the handles on the sides. But it looks like, due to the space taken up by the handles, there is no room left for a 3rd gauge. This is my scenario: I need to mount a boost gauge and an A/F gauge, plus a (standalone) shift light. I know that is a less-than-ideal location for a shift light, but if I can see it come on while looking straight ahead, I would rather have it there, than sticking out somewhere else. Out of curiosity, what do those panels above go for?
Custom User Title
My kid has a boost gauge, an AFM, and a manual boost controller - I believe he got the panel insert and the boost gauge and MBC from Lindsey.
The package came with an analog AFM gauge but he replaced it with a more accurate digital one (from Innovate) when he got his wideband O2 sensor. I don't have a picture of it but it looks real good - like it's s'posed to live there.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
Around $75 I believe here a couple more pics same place.
![]() ![]() Good luck with finding the rigth set up.
All Spooled Up
That's kind of spicy, for what it is. Is that the radio above it? I have the late style console, and my radio is where the gauges in the picture are. I would have to delete the compartment below it, and put my gauges there. It's starting to look like I'm going to have to make the damn thing myself, anyways.
i deleted the box below and put the gauges there - the box just popped out and the gauges just popped in
Flash you got pics your's are very nice.
Just FYI... That last one ernie posted is in a 911
here's one - the plate is no longer available though
Already told you on some other post you got eyes like a hawk,never dind't realize it since those gauges pics were so close together, but still can't hurt migth help him with the project & flash thank's your is a neat installation thinking of doing the same in mine I kept your pic on file hope you don't mine.
not at all - i get to get back in there in the next couple of weeks to change the vacuum gauge to a boost gauge, and possibly the clock to an A/F meter, both due to the new supercharger i am installing
also installing the bypass for the deck at the same time so i can program on the fly |
Custom User Title
Here's the link to Lindsey's package. It really does look quite nice. And it just pops in. GAUGE PACKAGES at LINDSEY RACING - Your Porsche Performance Parts Center My kid got the #3 package.
Garage Helper
I could not find a panel for my three gauges that was economical so I made my own - easy.
I used Carbon Fiber Material - a finished flat plate that started out as 12" x 12" and cut out a piece that was 7 3/8" x 2 3/8" then with a Milwaukee 2" hole saw drilled/sawed out the three holes + 2 more small holes at the bottom corners for the mounting screws - easy.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
All Spooled Up
Nice, but I don't think I could get used to having my gauges tilted like that. It reminds me of have tilted pictures on a wall, or something. But I know what you mean by none of the one's for sale being very economical. I think I am just going to cut one out of a 1/8" thick piece of black poly.
Garage Helper
Yep each to their own as I actually like them on the tilt - they are for me just easier/quicker to read in my case. I found my self in the past sort of tilting my head straight to read the gauges in straight up fashion. After this set is installed and the car is running I will place some hobby tape (1/8" self stick vinyl tape and probably red) at the normal or red-line positions according to the gauge, etc. for quick glance..............
I choose Carbon Fiber but plastic or aluminum plate will work just as well as it all does the same function.
Lindsey Racing has a number of different options for gauge panels.
You tilt them so "normal" is straight up regardless of the gauge. So you know all is well with just a glance -- old racer's trick. Boats too -- when you're bouncing around at 80mph on water it is kinda hard to read all those little numbers..., you just give a quick look and if one is different than the others you know something is awry.
10 E92 M3 13 Jeep GC Limited 98 Jeep Cherokee 87 951 C3 Stingray |
Garage Helper
Let's see thats 5 votes for Lindsey Racing, 3 votes for DIY and 1 vote for 9xAuto
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word Last edited by Cocacolakidd; 12-18-2009 at 12:10 PM.. Reason: sp |
