Pulling out fresh air blower assembly
Tracking a water leak in the passenger footwell shutting down the DME computer.
I already checked the battery tray and it's solid and no visible rust areas. Sprayed water too, no leak
Anybody with experience pulling out the fresh air blower assembly?
Looks like it's stuck to the mount opening pretty tight.
What type of seal did you use?
Thanks.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 12-14-2009, 05:55 AM
white944cup's Avatar
Do you have any holes in the thin plastic cover over the blower assembly? If so, water will get into the blower and work it's way into the footwells. The cover is very fragile and gets damaged easily. I repaired the holes in mine with some aluminum tape applied to both sides and painted it black to hide the repairs......it stopped the water intrusion and looks OK for now until I get the time and incentive to replace it later on.....
1988 944 Turbo
Guards Red - Black Leather
Autothority Stage 2 Chip Set
Weltmeister Strut Tower Brace
1984 944 - Sold to rcecale
Old 12-14-2009, 09:28 AM
Thanks White944.
I already bought a new black plastic cowl cover from Sunset Porsche ($50). I just need to pull out the blower assembly and reseal it.
I already got it off. I had to use a pry bar to lift off the seal from the sheetmetal. It is sealed with butyl rubber pressed against the sheetmetal and blower base. The front of the blower assembly has lifted off the seal and leaking water into the passenger footwell.
I will take pics later.
Old 12-14-2009, 10:02 AM
Hugging the curves
misnblu's Avatar
I'm listening to this thread because I've got leakage issues too.
I've only had the car a few weeks now and although the car is excellent condition, it leaks like an old man that forgot to wear his Depends.
So it's imperative for me to stop this leak asap.
Listening and subscribed.
www.misnblu.com
1986 Porsche 944 8v
Old 12-14-2009, 04:03 PM
cowl removed
Cowl removed exposing the fresh air blower.
Battery tray is good.
Fresh air blower removed. Cleaned up the opening ready for new seal. Two electrical connectors, two vacuum lines and one outside temp sensor removed.
Bottom of blower with old butyl rubber seal removed. 3/8" Butyl rubber seal in a box.
New seal installed on the blower bottom
Butyl rubber seal in a box $13 from the glass supply house.
Finished. Installed new plastic cowl.
Ready for water spray test.
Old 12-14-2009, 05:40 PM
Hugging the curves
misnblu's Avatar
Nice little how to man and looking good.
Good luck with it and now I've got a better idea on what to look for and where to go.
Thanks.
www.misnblu.com
1986 Porsche 944 8v
Old 12-14-2009, 06:20 PM
Update after some days of heavy rain
The passenger side foot well is now bone dry.
My foot well leak affecting the DME connector was due to the failed seal in the fresh air blower opening.
Old 01-01-2010, 02:40 PM
Griffinroydonal's Avatar
Good information and pictures in this post . That is the same stuff used for windshields . I have used it on tail lights also - Works great every time.
Warning - I play with Porsche's
1970 -914 / 1982 -911
1984 -928 / 1987 -928
Old 01-11-2010, 07:00 AM
