Will program for food
Rear suspension torque specs
Where is a good place to get torque specs for my rear suspension? I just replaced rear wheel bearings and bushings. Once I get it buttoned-up, it would be good to know the torque for the spring plates, alu trailing arm, that funky spring plate end cap that also squeezes in the body, etc. Thanks for any help.
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
Haynes Manual Ch 10 pg 163 lists torque values all on same page or try Clark's Garage
88 944 na 07 335i 12 Cayman |
Don't have haynes and already checked Clark's. Guess I'll look for a haynes, do they have one for an S2?
Dude if you have the manual and know the page number already just post the spec...
Posts like that are why I avoid the VW vortex with corrado issues... |
Bearing flange-to-cross tube 34 ft-lbs Bearing flange to body 52 ft-lbs Thrust bearing to bearing flange 34 ft-lbs Thrust bearing to body 34 ft-lbs Mount to body 34 ft-lbs Mount to strut 17 ft-lbs Trailing arm to rear axle nut 66 ft-lbs Trailing arm to cross tube 45 ft-lbs Shock absorber to body bolt/nut 45 ft-lbs Shock absorber to steel trailing arm nut/bolt 45 ft-lbs Shock absorber to aluminum trailing arm bolt/nut 90 ft-lbs Stabilizer suspension to rear axle strut and stabiliser 34 ft-lbs Stabilizer clamp to rear axle cross tube 17 ft-lbs Brake backing plate to steel trailing arm 43 ft-lbs Wheel hub to stub axle (steel control arm) 280-332 ft-lbs Wheel hub to stub axle (alum control arm) 340 ft-lbs. There you go....
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
Thanks mucho smokin!
