Drop and Shutter Fix Q's
Since I bought the car it had the idle drop and shudder symptom. I followed fr-wilks's procedure found here: www.the944.com, to bypass the TPS and set the idle with the throttle body air bypass screw. I have a late (85.5) DME and AFM so my question is what is the cause of this in the late model, as I thought this should only effect early cars? I was thinking of getting wilks's chip which should remedy this, but was looking for some incite into the root cause...... software bug, bad TPS???
Many Thanks
Current: 2014 Jetta SE 1.8L Turbo
2001 Civic 4 door, totaled
Red 1985.5 944 NA sold
Maroon 1985.5 944 NA sold
Old 01-05-2010, 06:48 PM
The TPS tested Okay per Clark's, anyone else have experience with late model shudder and using wilk's chip as a fix?
TTT
Old 01-06-2010, 06:48 AM
Root cause is that fuel shuts off totally (and sharply) when you close the throttle. That is probably the reason for the throttle cam that everybody removes, it helps to smooth the transition due to more mechanical advantage at the closed throttle end of travel. I have seen the bypass fixes, but I was wary of them.
I think the chip(s) fix it properly, but not sure. It is nice to have the fuel shutoff when coasting (saves gas) but annoying trying to drive smoothly at low speed.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 01-07-2010, 06:50 AM
unindicted co-conspirator
looneybin's Avatar
i fixed it with a FR Wilks chip
I don't know how it works, i'm not a computer science guy, but it fixed the shudder and also got rid of the flat spot at 3K rpm
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 01-07-2010, 08:25 AM
It seems strange that porsce would design the fuel delivery this way. I always thought it was a software bug or an engine electronics malfunction.
Old 01-08-2010, 04:51 PM
If you have a late DME and AMF in a early car, will the chip help with the shutter?
Parker Furer
1984 944 alpine white
Old 01-08-2010, 08:14 PM
Thanks guys for the response, I ordered wilk's. He said as stated on his website that the shudder fix is built into the chip and should solve the problem. I'm also excited to see how the car feels with the shift in the power band.
Old 01-09-2010, 04:53 PM
I was very happy with the Wilk's chip in my early 944. My DME had a switch for factory setting or chipped setting. Needless to say I never used the factory setting.
Old 01-09-2010, 05:38 PM
zedsn, is your chip for the early DME or late?
Parker Furer
Old 01-09-2010, 08:06 PM
Mine was for the early 944 and isn't as easy to install as a later DME. The early computers have to have the chips soldered in. I bought my Wilk's chipped computer used here on Pelican and to me it was well worth the money. No big HP gains but car ran smooth and had no flat spots during acceleration. I think it gave my 83 NA like 5 extra HP.
Old 01-09-2010, 08:14 PM
Thanks, I'm not to worried about the HP gains, Just a more smooth running motor.
Did the chip help with the shutter?
I was also looking at the swap to late DME and AMF cause I've heard it makes it run smoother.
Parker Furer
Old 01-09-2010, 09:52 PM
Yes the chip fixed the shutter. You will have to take a late AFM and DME and use them together and I have heard the same thing but don't know for sure though. There was also a write up on pelican about fixing the shudder a couple of years back and it supposidly worked. Maybe you might want to look in the old threads and it won't cost a dime.
Old 01-10-2010, 05:24 AM
