Send a message via AIM to ScoobySteve
Unique Steering Wheel Vibration
For a (very) long time I've had a funky steering wheel vibration. It's a speed dependent pulsing and only when turning right. I've recently replaced my front struts (and strut top bearings) hoping that would fix eliminate it. No dice. Here are some things I've done that *haven't* made a difference:
- New Struts
- New strut-top bearings / mount
- New tires
- Alignment
- Wheel balancing
Here are some things I think it *could* be:
- Warped brake disc
- Unevenly worn pads
- Worn control arm bushings / castor block
- Worn balljoint
- Loose / worn front wheel bearing
I was hoping you guys could give me an idea of which are the most likely so I'm not just throwing money and guessing. It's not that bad....more annoying than anything else. But with the struts and tires sorted everything else feels so nice as to highlight it.
-Stephen
00 Boxster S 6MT
03 Subaru WRX w/EJ207 swap
16 Cayman GT4
21 Genesis G70 3.3T
Old 01-04-2010, 02:20 PM
You left off "Bent wheel".
That's my educated guess.
Porsche specifies .040 out of round (which is minuscule.)
Good luck, George Beuselinck
Old 01-04-2010, 03:20 PM
Well, it's easy to test. This might be an excuse for a new set of 16" phonies in lieu of the FauxFuchs.
-Stephen
00 Boxster S 6MT
16 Cayman GT4
21 Genesis G70 3.3T
Old 01-04-2010, 04:33 PM
Certified Porsche addict
The Glademister's Avatar
I had a low frequency vibration on the '87 944S I owned. It only happened during left turns at 35-45 MPH. I suspected ball joints but after discovering uneven tire wear on the passenger front - it turned out to be the wheel bearings on the wheel. Actually it was the bearing race had a small ding in the surface. Probably would have taken the bearing out eventually. Hard to detect even using recommended diagnostic procedures.
Tennessee Region SCCA & PCA
Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend)
Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11
Old 01-05-2010, 04:57 AM
All Spooled Up
"always make sure your bearings are tight" (but not so tight that they don't turn freely)
There is more chance of dinging a ball or a race when hitting a harsh bump, if they are loose (plus other issues).
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 01-05-2010, 06:15 AM
ernie9944's Avatar
Had the same problems once very annoying went at everythings you can think off "bearings- tires- ect ect" turn out to be one of the wheel don't take much of a bent neither to raise havoc.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 01-05-2010, 07:54 AM
In the Fires of Hell.....
kdjones2000's Avatar
Replacing/upgrading the caster blocks to the 968 ones fixed an annoying wobble at ~80MPH for me.
The original ones had cracked rubber and allowed control arm movement....
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 01-05-2010, 09:55 AM
On Boost
Paulyy's Avatar
I have 968 caster blocks on my 951, they use less rubber and imo they're way better
86 952 GTX3076R, M-Tune, eBoost 2, CEP/JME cam, CEP head.
Old 01-08-2010, 05:47 AM
