onrails's Avatar
Send a message via Yahoo to onrails
944S clock light
Does anyone know if the clock on an '87 944S is supposed to have a back light when you turn on the dash lights? The time works fine, but I can't see it at night? Before I order one for $150.00, is there a bulb or connection I should be looking for?
Old 12-11-2007, 06:10 PM
DMRK's Avatar
yes there is a bulb in there. I think it is always on when the car is on so that is why they are burnt out after 20 years.
Dave
82 928 Weissach #14
Old 12-11-2007, 06:22 PM
DMRK's Avatar
go here...
http://www.clarks-garage.com/
...and click on the garage shop manual link on the left then scroll down to clock. that will tell you how to change it.
Dave
82 928 Weissach #14
Old 12-11-2007, 06:27 PM
Yes there is a light that can be replaced, you will have to unsolder it from the removeable socket (easy) and solder the new one in (again easy). I did mine awhile ago but can't remember the type/number, it is rather small. I pulled it out first then went to my local parts house and got a new one.
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 12-11-2007, 06:29 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Pelican actually has the complete assembly and it's pretty cheap.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 12-11-2007, 07:30 PM
hermesbooking's Avatar
Send a message via Yahoo to hermesbooking
PM Sent
I Love the Smell of Jet Fuel in the Morning!
86 Silver Porsche 944 N/A - Alpine CDA-9857
KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade
http://www.c28.com/?adid=st&iid=25349
Old 01-21-2008, 03:12 PM
That Guy
Techno Duck's Avatar
For future reference, the bulb part # is 944.641.900.00 . $6.16 from the dealer.
Its a special bulb in that the base and bulb are one piece (soldered together. You can unsolder the leads and use a generic replacement.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-21-2008, 03:43 PM
In the Fires of Hell.....
kdjones2000's Avatar
Not to digress too much, but will that same PN work for the headlight switch light?
How do you get that light out? I tried pulling on it, and it seemed to be VERY tight.
TIA, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 01-21-2008, 03:53 PM
That Guy
TIA, Keith
Keith, the headlight switch bulb is a generic bulb you can get from your local autoplace. If its not pulling out, you just need to pull harder really. The bulb which was blown out on my car was very hard to remove, after i replaced it the new bulb slides in an out easily. This is of course refering to a '85.5+ car. I forget the #, but its 2170 or something like that. You can look it up in the book under instrument cluster light.
What makes the clock bulb unique is that its soldered to the base, which happens to also be unique to the gauge cluster bulb bases.
Jon
Old 01-21-2008, 06:49 PM
onrails's Avatar
Thanx guys for all your input. Seems easy enough. I'll be seeing the dealer Friday.
Old 01-22-2008, 07:54 PM
onrails's Avatar
Hey HPSERVERTECH, sounds like you have some good sounds going on. I've got similar equiptment. Alpine head unit, 4- 6 1/2in. Infinity (I custom installed), Sony Explode Moble ES 5 channel front amp, JBL 600 sub amp, with 3 JL Audio DVC subs in a custom box I built. (looks factory with only 12" lost behind the back seat) I saw it on-line & built it in a day. Plus, I have the Kenwood digital EQ to help with the almost 1400 watts (that I'm using of it). Wouldn't mind seeing some pics. And I'll share too of course. I've also got the plans for a 12" sub that fits in your spare tire compartment that I did on a prior 944 which would put out a Zippo lighter! As long as you're not worried about having a spare tire. Hope to chat w/ya. Chris.
Old 01-22-2008, 08:36 PM
Politically Incorrect
onZedge's Avatar
Originally Posted by Techno Duck View Post
...2170 or something like that...
2711 is the bulb without the socket. 2721 is a little brighter. I got a box of the bulb/socket combo units at NAPA for about a buck each. (Part number escapes me) It is the same thing used in older VW's. Imagine that - VW parts that fit into a Porsche!!
Edek
'87 924S
'91 535i
Old 01-23-2008, 04:18 PM
TNT25169's Avatar
Send a message via AIM to TNT25169
I can't get lights to light up. I've tried 3 different clocks, soldering and not soldering the ends of the bulbs on. The clock looks fine in the light but the bulb just won't light up. Help?
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 11-21-2008, 01:04 PM
Porsche Crest Clock is a Dark Clock
I've been working with this problem for a long time. I think Porsche decided that the Porsche 944 doesn't deserve a "lighted" Clock. I replaced the Light in my 1985 Late 944 Clock thinking it would light up on the Dash so I could read the time--but it doesn't!!! It's dark as the depths of hell, and you can barely read the clock during Daylight. The Light in the Clock only lights up the Digits and probably lights up the Backside of the Dash which is pointless. I don't get it. Also the Light on the Gauge Cluster is very dim. Anyone with any insight to this problem--I'd appreciate it like this Owner posting this message would. It's a no-brainer to light up a Clock in a Car for night driving, etc. But I don't know what Porsche is thinking with this one. Any Ideas would be appreciated.
Old 11-25-2008, 04:00 PM
I first bought just a bulb and couldnt get it out of the holder. So I bought the assembly and it worked fine after that.
72 914 Sold
84 944 Sold
85.5 944 Sold
78 924 (first car) RIP
Old 11-25-2008, 06:37 PM
My clock bulb also appears to be burnt out, what color does the clock illuminate with a stock bulb? Also, has anyone tried to retrofit an LED to illuminate the clock?
'87 944
Old 11-11-2009, 09:46 PM
Hi SanFran, Check out the link below for how to brighten up the gage lights. It works great.
Reflector Housing Rebuild - Porsche 951 - www.texasblake.com
Cheers,
Larry
Old 11-11-2009, 10:46 PM
Nope the clock is shot and you should pull it out and send it to me...
Old 11-11-2009, 11:29 PM
I just got through messing with my clock... here's what I found out:
The ignition power wire that runs to the clock (giving it backlight power) also runs through the stereo harness. There are 2 green wires which meet on a single pin in the radio harness connector, and when I installed my head unit I had just cut the connector off and used 1 of the wires. So the connection was cut off to the lcd clock. The other thing I noticed was that the wires on my clock connector did not match the pinouts on the wiring schematic. Apparently someone had opened up the clock connector and not put the pins back in the proper orientation. After I fixes those 2 things my clock now lights up perfectly.
Old 11-12-2009, 04:27 AM
All Spooled Up
That's exactly what I am contemplating doing, using a 5mm super-bright white LED with a current-limiting resistor. I'm going out and buying a string of LED-based christmas lights today. They should also work for my motorcycle's neutral, turn signal, and high-beam indicator lights, which seem to blow out very frequently. Not to mention that they can be hard to see during the day. I think that LED's would make them much brighter. I'm tired of waiting for them to show up with the proper bases, at the auto parts stores.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 11-12-2009, 07:39 AM
