what is this and whats it for
![]() It is under the hood and on the drivers side. What is this for, and what is it... also the large hose on it is cracked...what effect might that have? thanks |
I believe it's the idle stabilizer & it does stabilize your idle & if the hose is crack on it better change it before it start giving you problems. What year is the car?
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Proprietoristicly Refined
Correction-----This is the Vacuum Control Valve
pn 944 110 429 00 sells on Pelican for $680.75. Connects to a VW fuel breather valve... Last edited by John_AZ; 01-17-2010 at 04:30 PM.. |
Politically Incorrect
That is the Evaporative Emissions Flow Regulating Control Valve. it is connected to the plastic EVAP on-off valve. If the hose is breached, you will get a gas vapor leak/odor. The Idle Control Valve is located under the Intake Manifild.
Edek '87 924S '91 535i Last edited by onZedge; 01-17-2010 at 04:14 PM.. |
Not sure about the price difference. I do not have an interchange for the part.
Pelican: OEM-94411042900 Genuine Porsche Part: VACUUM CONTROL VALVE - This is a special-order, non-returnable, Porsche part (availability and shipping charges may vary). [More Info] $680.75 Used would be the best way to go IF needed. |
Ernie,
I think you are referring to the ICV/ISV----My mistake I was referring to the Vacuum Control valve that onZedge mentioned. I read your first post incorrectly. |
