marko's Avatar
Is this the oil relief valve?
I can't tell exactly what this is from the PET, oil pressure relief valve? It's leaking oil.
'90 944S2 cab - sold after 20 years, will not be forgotten.
'04 Mercedes SL500 - Nice but my S2 was more fun to drive.
Old 02-07-2010, 01:30 PM
Proprietoristicly Refined
John_AZ's Avatar
Without getting under my car, you are pointing to an oil plug-part 37. You should just need an aluminum crush washer M18x24 to seal the drip.
Get another for the oil pressure sender-part 30. Clarks says it is an M18x24 crush washer. I use all aluminum crush washers.
Get a third for the OPRV valve-part 31. Crush washer M20x24, The OPRV valve head is 24mm opposite your arrow.
If you take off the oil pressure sender, take care with the terminals. They are hollow and will snap/break easy!, Do not reverse the wires. If you do the oil pressure guage will peg to 5 with the key in.
GL
John_AZ
Old 02-07-2010, 03:10 PM
marko's Avatar
Oh good, that sounds pretty easy. Thanks for the help!
Old 02-07-2010, 06:18 PM
Redline Racer
HondaDustR's Avatar
Interesting. I had the wires reversed when I got my motor back together and the guage didn't peg with the key in and the motor off, but would instantly peg as soon as it got oil pressure. It would peg with only the key on if they were disconnected altogether. It must have been the low pressure switch for the idiot light messing with it.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 02-08-2010, 10:06 AM
