Side mirror disconnect
trying to find out how to disconnect the side mirrors from the door harness once I have unbolted them from the doors.
I am trying to save the harnees, I do not want to cut them if possible.
Old 02-15-2010, 10:19 PM
You can get a little tool at your FLAPS... Mine is made by lisle.
Detail Page for 56500 Terminal Tool - Lisle Corporation
there should be a wiring diagram on clarks garage....
Old 02-15-2010, 11:27 PM
KLR KLR is offline
KLR's Avatar
You basically have to pop the wires out of the female plug inside the mirror housing. If you have the right pin removal tool (do a search for the AMP part number and places you can order it), it takes under a minute to pop them all out -- no problem.
1987 951 - Stone Gray / Burgundy
15psi Guru Chips, Reliaboost, 3-bar FPR, KW Variant 3 Suspension, OE Euro Driving Lights, Iceshark Wiring Kit
Old 02-21-2010, 06:59 AM
ya I figured it all out now. I just used some small screw drivers, but Its crazy you have to tear the mirror apart before you can disconnect it.
Old 02-21-2010, 08:11 AM
