porschetub's Avatar
Later engine in early car
I'am in the process and swapping 89 2.7 in early ROW 85 car,can anyone tell what the 4 wire connecting block near the ecu plug is for?it is about 60mm long and about 10mm wide and has provision for 8 wires but only 4 are connected.
I'am presuming it goes to the instruments?.
Are there any other issues using this loom in an early car?
Don't want to use early loom if possible ,thank you.
Old 02-28-2010, 01:58 PM
porschetub's Avatar
Bad photo ???
Hi ,have photo of loom plug ,not a good one but should give the general idea.
Has part # 944 612 554 00 if thats any use ,cheers
Old 02-28-2010, 02:45 PM
Could you take a closer picture of it?
Cheers,
Larry
Old 02-28-2010, 04:54 PM
ernie9944's Avatar
Porschetub_____ Your to close from the object back up a little way from it then you'll have a clearer pic
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 02-28-2010, 05:26 PM
porschetub's Avatar
Yea sorry about the photo hope this one is better???,thank you
Old 02-28-2010, 10:22 PM
