Crank pulley bolt
Any locktite, or anti-sieze on the bolt itself? 155lbs right?
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 03-21-2010, 02:34 PM
winter-hater club member
nynor's Avatar
no locktite, yes 155 lbs.
"COOL PRIUS!" - Nobody Ever
Old 03-21-2010, 02:53 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
I've used anti-seize but no locktite. No issues and yes the locktite makes it slightly easier next time. I also think it gives slightly more acccurate torque readings since you're "gliding" up to the proper torque rather than "skipping" up to it as threads bind and slide against one another as they stretch. In any case, no issues doing it that way. Yeah, 155 ft-lb sounds correct. Get a big honkin' 1/2" drive torque wrench.
Black Cars Matter
Old 03-21-2010, 03:50 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Add-ons of any type will give false torque readings - Torque ratings are for a dry bolt/screw only.
The dry bolt torque ratings are figured with a coefficient of friction (approx. 0.02 for dry steel nuts and bolts. - unless there is a stated/named variable introduced.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 03-21-2010, 05:48 PM
Thanks guys.
Old 03-21-2010, 07:21 PM
porschetub's Avatar
Hi,100% on the no additive thing,get it right once first time ,I learnt the hard way getting someone else to do my belts and they didn't tighten this bolt costing ME a previously good 2.5 motor,cheers.
Old 03-28-2010, 11:59 PM
