universal O2 sensor which one?
I've been searching countless threads, and am wondering what is the correct universal 02 sensor. I have a 3 wire.
I've heard of these working:
13913
15725
15726
I'm not sure which one to buy. However the one I'm running now is a single wire just spliced into the green wire. WTF.
Old 03-26-2010, 12:19 AM
Mark944na86's Avatar
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
15735
Currently 1990 944 S2, Black on Linen, 17" Turbo Twists
Old 03-26-2010, 01:26 AM
smokin_944's Avatar
What year is the car?
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 03-26-2010, 04:57 AM
I bought the 15725 with connectors supplied at Auto-zone $54 back then for the 1990 S2.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 03-26-2010, 05:09 AM
Proprietoristicly Refined
John_AZ's Avatar
Follow the Bosch connection instructions. DO NOT SOLDER
http://www.boschautoparts.com/Technical%20Resources/Oxygen%20Sensors/OxygenSensorInstall.pdf
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-26-2010, 06:51 AM
I purchased a Bosch #13942 (for a 1987-88 Ford Mustang V8) sensor from NAPA for $43.99 + tax, and spliced the wires into my 968's connector, using solder and heat-shrink tubing. I kept the wires exactly the same length as the OEM so as to avoid significant changes to the overall electrical resistance.
That was 42k miles ago, and it's still working flawlessly.
Old 03-26-2010, 07:14 AM
That's a good link john. Thanks
Old 03-26-2010, 07:18 AM
Do not solder? BS...old wives tale. Solder works fine, and my car is a living testament to it.
Old 03-26-2010, 08:33 AM
John_AZ's Avatar
What you choose to do with your car is fine.
Unless you can prove solder is superior to crimping with PDF files and manufacturing technical instructions, I am not convinced and the forums purpose is to provide owners with accurate help and assistance.
Additional resources-NGK Oxygen Sensor installation:
Tech info - Oxygen Sensors Overview
If English is not your first language:
http://www.ngksparkplugs.com/images/pdfs/Universal_Instruction_Sheet_11-16-04.pdf
Reworded on eBay and updated 3/10/2010:
eBay Guides - UNIVERSAL OXYGEN SENSOR INSTALLATION INSTRUCTIONS
AND another from FR Wilk:
Oxygen Sensor
Old 03-26-2010, 09:51 AM
Toofah King Bad
Rasta Monsta's Avatar
pwned.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-26-2010, 10:33 AM
I can tell you've got your hands full trying to drum up all those links.
Old saying: Chrome won't get you home.
Old 03-27-2010, 06:54 AM
Old saying: Google is your friend.
Old 03-27-2010, 07:43 AM
winter-hater club member
nynor's Avatar
second the 13942. ~$35
"COOL PRIUS!" - Nobody Ever
Old 03-27-2010, 08:37 AM
All Spooled Up
Is that really an old saying? Although I do use the service regularly (it's my home page), I can't say I've ever heard the "saying". And, relatively speaking, I'm pretty old!
All BS aside, I'm going to have to go +1 (or whatever the actual count is at this point) on the no-solder-on-the-O2-sensor-wires gig.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 03-28-2010, 05:23 AM
Shoot, now I'm going to have to bow to popular opinion and go out and yank my O2 sensor, cut out that unpopular soldered section, and replace it with a popular crimped wire, lest I have a big breakdown with next time I start the engine.
Thanks for the poll numbers, fellas!
Old 03-30-2010, 08:29 AM
Toofah King Bad
No poll needed. Listen to the engineers at Bosch.
Old 03-30-2010, 11:13 AM
Same Bosch engineers who brought us these cutesy-pie proprietary connectors which magically make a $40 sensor into a $140 sensor?
Old 04-02-2010, 08:35 AM
I soldered mine on my 944T six years or so ago and it works fine. I think the no solder business is an old wives tale. The supplied connectors are good. If you go with solder, I suspect some installers will use electrical tape to finish off the connection. If you do that and the splices are adjacent, sooner or later the tape will deteriorate and the wires have a good chance of shorting out. I cut my wires so the splices are not next to one another, used heat shrink tubing, then included the whole package in split tubing.
The reasoning I have read regarding not soldering is so that the sensor can receive air. I don't see how that is possible given that the pressure inside the exhaust lie is higher than atmospheric. There is no pressure differential to drive air in that direction. The only other mechanism that could deliver air would be diffusion. That is far too slow to do anything.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 04-02-2010, 09:07 AM
nynor's Avatar
this sounds reasonable to me.
Old 04-02-2010, 10:44 AM
John_AZ's Avatar
I will overlook the previous solder posts but comment on the $140 O2 sensor.
PLATINUM
Todays spot price for PM platinum is $1680 an ounce.
Platinum is layered on the O2 sensor for supreme conductivity and longevity.
Oxygen Sensors & Emissions - Facts & Repair Advice
The $19 to $50 sensors will not have this.
Also the design may be different:
Oxygen Sensor Design
YMMV
John_AZ
Old 04-02-2010, 11:00 AM
