De-rusting and Re-painting components - Suggestions?
The front struts on my 85.5 look pretty rusty...but while this rust is actually flaking off in places, its a pretty thin layer with what appears to be good metal underneath. Same with my rear CV axles - looks like I could scrape them down and have basically good metal to work with.
So I'm thinking that I could do a careful and thorough job of removing this rust, and then repainting these components. I've done a bit of "de-rusting and repainting" in the past...typically beginning with a thorough sanding/grinding, then undercoat with Rustoleum and topcoat with some type or other of auto paint - but the rust always seems to come back within a year or so. With this in mind, does anyone have recommendations on what de-rusting procedures I should follow - and what products I might look for to help my re-painted components stay "fresh" a while longer? Thanks! |
bench grinder wire wheel it down to shiny metal. try rust neutralizer, primer then paint. it might help
Garage Helper
Also check with Eastwood as they have several products that are what you are looking for - Rust encapsulation, etc.
Automotive Repair Tools, Automotive Accessories, Auto Body Tools - Eastwood Company On the first page go to: Rust solutions - a red tab. A good company with good people to deal with.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
POR15
Buy the 3 quart kit online...has a cleaner, prep and the paint. The best out there for rust fixin'.
Rick Harrison 1988 944S 17 inch Cup 2's, euro bumper conversion Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake MaxHP chipped |
I like soda blasting to remove scale and rust. Cleans up the surface well. Easy to do. No hazmat required. And once you wash/rinse/dry, you follow the application instructions for the paint you're using. Won't hurt/warp the metal like sand, nor is it as operator un-friendly, healthwise.
Just watch out, although it is "environmentally" friendly, it will kill your grass. |
Electrolysis works great, especially for odd shapes and fragile parts like springs. The article below describes it pretty well. No special equipment needed either.
Best Way - Electrolysis for Rust Removal | eHow.com
1983 944 - project mode 2002 Ford F150 - every other daily driver 1976 Honda Goldwing - the other days |
+1 on electrolysis. I got a bit Blue Container with a lid from Lowes like 7$ ( 99% recycled plastic) and a large box of Pure Baking Soda from the Laundry isle at Walmart. and A Large FLat Metal bar about 1/4 inch i think purchased at lowes in the metal department which i used as the sacraficial piece that was pretty wide to make a lot of surface contact with water.
I used it on some Garden Tools, some things for the Kitchen... And I also Used it to take the Rust of My headers And Painted black( looks soo sweet).... Its fun and if you have kids it makes a cool science project ![]() Oh and a cheap Battery charger lol Note: there are many solutions of baking soda with water out there.. i used a decently concentrated version Regards J
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
Oh, you can use an Etching Primer which you can buy at walmart if you want to go crazy other wise just a paint that has rust preventative works
I use jumper cables off my truck. The larger battery can handle it.
Ja, If I could figure out how to get my car trailer into a bucket, that electrolysis thing would probably work nicely
Garage Helper
Drive on into the pool - add soda - run electric lines with the clothesline metal pole & plug into the wall - etc.
I'm a big fan of sand blasting (don't use real sand) and powder coating (far more durable than paint).
Thread Tools | |
Rate This Thread | |
