SLED GUITARIST
Dan Himan's Avatar
Speed sensor?
So i noticed a don't have a speed sensor on my 1988 944S, it runs good. What is a speed sensor for anyway?
Old 04-17-2010, 09:49 AM
SLED GUITARIST
Dan Himan's Avatar
Hall sensor
Did the hall sensor replace the speed sensor?
Old 04-17-2010, 12:34 PM
Actually, the one that you're missing is the TDC sensor. The 944S and 944S2 used a different arrangement than the 8 valve cars. They use a flywheel with notched teeth and one tooth is missing to account for TDC. The hall sensor is used for knock sensing... since there is only one knock sensor, the hall sensor is input to let the DME know which of the two possible cylinders (either 1&4 or 2&3) is the offending cylinder.
Good luck, George Beuselinck
Old 04-17-2010, 01:00 PM
SLED GUITARIST
Dan Himan's Avatar
so i have one, maybe the ref sensor, on top of the fly wheel housing, and the round hole is for the tdc sensor?
Old 04-17-2010, 01:30 PM
Well, I guess that I should have put "missing" in quotes. You only have a speed sensor (by design) and it counts the teeth on the flywheel (by design) and it is missing one tooth (by design) so that it knows when #1 is at TDC. Since (by design), it already knows where TDC is, it doesn't need a separate TDC sensor.
Clear? Crystal?
Old 04-17-2010, 02:49 PM
SLED GUITARIST
Dan Himan's Avatar
Ok thanks. Good to know i'm not missing anything
Old 04-17-2010, 06:50 PM
Can you just spray with those rust converters? I know it sounds cheesy, but I thought they worked in the same way--by reducing rust to black oxide.
WARNING: Do not buy from Ron Kirby of Fort Thomas, KY (currently RRRacing1970).
Old 04-20-2010, 03:01 PM
Where does the other end of the TDC Sensor plug into?
Old 05-22-2010, 06:06 PM
Redline Racer
HondaDustR's Avatar
It's also got a hall sensor for cam position right?
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 05-22-2010, 06:23 PM
