Porsche Crest 83 n/a no spark
Hello, I have a 1983 944 N/a with no spark, I have checked Dme relay. Possibly alarm module? How do you jump the alarm system? and also dme has some corrosion is it possible the main DME not the relay has gone bad? would that lead to no spark?
Old 04-23-2010, 07:50 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
Whoa! newbie alert
Hey buddy, lots of DME info here, just search the forum for it. Also check out Clarks Garage, good info there as well. There are current flow diagrams for your car on this website. IMHO, check them out and trace the circuit power one way or the other. Check power to the coil and DME Relay. It doesn't hurt to clean the fuses and check the grounds. There is a real PITA ground at the bell housing. follow the ground from the battery to where it disappears behind the engine.
For no spark conditions it is a good idea to go over connections as well. I suggest checking the speed and ref sensor connections as they go a lot and will cause intermittent or no spark. Viel Gluk.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 04-23-2010, 08:10 PM
Electrical may be a PITA, but it is not overly complicated. Like SolReaver says, go through your connections. A $20 multimeter and a wiring diagram are all you need, the rest is just time and effort. Almost as simple as paint, and less of an art form.
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 04-23-2010, 08:17 PM
post you're info in you signature helps out alot. History of the car would help like. " I just bought the car and it has no spark" or " all of a sudden i don't have spark anymore
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 04-24-2010, 12:34 AM
SolReaver's Avatar
clarification
When I said PITA, I was referring to the ground connection that is hard to get to. Troubleshooting the electrical is fairly straightforward, a good meter, test light and the diagrams will get you through most difficulties. Paint is an art form as it takes a good touch to get a nice even coat and prep work can be really time consuming.
Old 04-24-2010, 09:12 AM
I say electrical on a car is PITA lol. Much harder than a motorcycle where all I have to do is remove the tank and seat. But still not complicated, just chasing wires.
Old 04-24-2010, 10:17 AM
