Marajit's Avatar
Downside of Cooler Radiator Temperature Switch?
On an '84.
I know it will turn on the fans sooner, but does it have any unintended consequences?
For instance, will it put a strain on the fan relay and on the fans themselves?
Peace to the Brave
1983, 1984, 1987 944 N/As
Old 05-17-2010, 04:58 PM
ernie9944's Avatar
Originally Posted by Marajit View Post
On an '84.
No not if you use the rigth one witch is 75°/70° don't go colder then that.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 05-17-2010, 08:25 PM
On an '84.
You have to match the thermostat and the fan temp switch, or the fans will just run with no coolant flow across the radiator.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 05-18-2010, 01:53 AM
rickharrison's Avatar
+1...match them up
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 05-18-2010, 05:53 AM
flash968's Avatar
cooling systems are touchy things - there is such a thing as "too low" or "too cool"
a perfect system will run 5-15 degrees above the thermostat point, and will vary no more than 20 degrees, regardless of operating condition
also, gasoline engines operate best when the coolant is 190-195 degrees (though emissions are reduced if it is more like 205)
that being said, fans should operate so as to come on just before the temperature of the coolant gets to the upper end of the acceptable range, and then shut off - dual speed fans should have the high speed fan come on during any anomalous condition that exceeds that range or adds unusual load
also, shrouding plays a large part in the efficiency of a cooling system - never delete fan shrouds or belly pans - contrary to common misconception, belly pans are there to IMPROVE cooling - removing them allows too much extraneous air into the engine bay, thereby reducing the negative pressure required for optimal flow through the radiator - in a perfect world, the only air allowed into the engine bay would be required to pass through the radiator first to get there
Old 05-18-2010, 07:17 AM
All Spooled Up
75°/70° is too low, unless running 160° (F) T-stat, which, for all intents and purposes, would be too low anyways.
Advice? --- Stick With Stock!
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 05-18-2010, 09:53 AM
