rrwebster's Avatar
Rear Wiper Missing...
on my new toy I have a hole in the glass... and some wires (3) near the hole.
is this (see picture) all I need to have a rear wiper again?
thanks in advance!
Robert
1983 Porshe 944 N/A 5sp Guards Red
Old 05-18-2010, 03:47 AM
ernie9944's Avatar
^^Robert why don't you simply deleted the rear wiper an use this wiper plug unless you realy want a r/w they come in two style
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 05-18-2010, 04:55 AM
rrwebster's Avatar
Ernie,
I had thought about getting one of those but really want everything that's supposed to on the car in place and functional... like it was when it was new. These are really great little cars... I'm really loving it.
oh... btw I've found out that is all I need and have already purchased one.
Robert
Old 05-18-2010, 06:36 AM
Before you install the new/used rear wiper motor drill out the rivets, remove the case and clean out the old caked grease inside and re-lube with white lithium grease. Check that the rubber seal is still soft on the shaft, so no water can get inside the cleaned up motor. Do a SEARCH and there should be a How To on here or on Rennlist.com.
Cheers,
Larry
Old 05-18-2010, 07:22 AM
rrwebster's Avatar
Cheers,
Larry
Larry... Thanks so much for that advise... will be much easier to do before the install!
Robert
Old 05-18-2010, 08:55 AM
