GreenWater's Avatar
Aluminum control arm to steel
I know this might sound strange, but I want to take off my aluminum control arms and put steel one on. My current arms are wore out. I just replaced the ball joints and it still shakes. The aluminum was too badly wore. I don't have the money to buy new alum. arms so I want to replace them with steel arms. I am only using the car as a daily driver, no racing. I am pretty sure that the steel and alum. are interchangeable. Will all the bushings work from my alum. arms.
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 05-23-2010, 11:32 AM
Yep, you will need new swaybar droplinks at the arm and the rear bracket that moves centerline to outside to adjust caster. This only works with 85/2 and 86 cars, since the 87+ offset means different dimensions for the control arms.
Good luck, George Beuselinck
Old 05-23-2010, 12:15 PM
J1NX3D's Avatar
my stepdad went from ali to steel arms on hiis '86 n/a racecar with no problems. as long as your're early offset i think you should be fine. you might want moore detailed advise than this though. [edit]there you go!
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 05-23-2010, 12:16 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
The 83 to 85 early steel control arms are basically the same in dimensions as the 85 late and 86. All of them were the early offset with mounting points/parts being same, if you use the steel A-Arm mounts. The difference is in the removable/replaceable ball joints on the early steel arms, with changeover aluminum arms the ball joints were not so easily replaced. Plus the early steel A-Arms were noticeably weaker than the aluminum A-Arms. For street only you may never notice the difference.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 05-23-2010, 01:30 PM
J1NX3D's Avatar
the early arms are easy enough to seam weld for a bit of extra insurance but for a roadcar its not really necessary.
- 6 spd/LSD
Old 05-23-2010, 01:51 PM
kens_74_911s's Avatar
Steel to Alum ? 85.5 arms on a 83?
If someone wants to use Aluminum 85/5 arms on an 83 what additional parts are necessary ? Mainly the sway bar drop links? Have to look into the camber adjuster mentioned. I had a guy looking to buy some used lower arms for his 83 but may be nice to upgrade since I have the 85.5 parts available 4 him.
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3
81 VW Caddy Pickup X2 now...
84,85x2 .86,87,944. 82-924,88-924s parted with inventory!
68, 70, 72, 73, 911~ 70,73 914 past P/cars
Old 06-03-2010, 09:56 AM
There is no advantage to changing to aluminum control arms from steel. Except to the seller!
Old 06-03-2010, 10:51 AM
