1990 s2 Cab without cold air
Recently the A/C stopped blowing cold air on my 1990 s2 Cab. The compressor is kicking on and off but tepid air (not hot) is coming out of the vents. Any suggestions as to where I could look before taking it in
Old 06-19-2010, 01:34 PM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
Is there still refrigerant in there? I'd check that first.
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 06-19-2010, 02:10 PM
I thought of that but was hoping it could be quick fix in the garage. On a side note I just had the head removed for some work Is there anything that had to be disconnected or could have been damaged on the heater valve during the process.
Thanks,
Old 06-19-2010, 02:25 PM
flash968's Avatar
heater control valve vacuum line?
Old 06-19-2010, 02:48 PM
marko's Avatar
Did you look at the site glass on the A/C drier while the A/C is running? It should be clear. If it is a milky white color, then you need more refrigerant.
'90 944S2 cab - sold after 20 years, will not be forgotten.
'04 Mercedes SL500 - Nice but my S2 was more fun to drive.
Old 06-20-2010, 06:08 AM
In the Fires of Hell.....
kdjones2000's Avatar
Well, it could be that your heater control valve is no longer hooked up correctly, blowing hot air in the mix with the A/C's cold air. I would look for the vacuum hose being disconnected up near the front of the head on the exhaust side of your engine.
Look at the sight glass as well when the A/C is running to check your refrigerant level as well.
Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 06-20-2010, 06:29 AM
Thanks, I will let you know
Rowalnd
Old 06-20-2010, 11:30 AM
Checked the refrigerant and the eye glass was cloudy so I will get it refilled.
On another note I noticed a 3 prong connector located behind the dist cap is broken exposing wires. They are in yact but exposed. What is this connector for?
Thanks again, Waxman
Old 06-22-2010, 12:03 PM
