RedBaron's Avatar
Question on Swaybar bushings
I am planning on replacing my sway bar bushings (One on the left side is shot due to oil/power steering leak and my bracket on that side is also broken). I use my car 95% on the street and I was browsing on Paragon and I saw that they sell Delrin bushings. What is the point of Delrin bushings and is there a huge difference between those and OEM ones?
Thanks,
Justin
Old 06-18-2010, 11:41 AM
oem ones are rubber and deform. delrin is hard plastic and does not deform.
if you're just going for street car, i'd just get new rubber ones. extra cost of delrin isn't going to get u anything
Old 06-18-2010, 12:05 PM
Will program for food
ghnat's Avatar
I've got delrin and they are great for auto-x, DE etc. Mine seem to squeak in cold weather, fyi...
For just street stock is plenty fine.
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 06-18-2010, 12:57 PM
porschetub's Avatar
Hi ,go for the OEM bushes unless you want more noise and hardness in your ride,rubber is used because its compliant with swaybar as Porsche designed ,there is a company in the UK that makes a halfway type (somewhere rubber and plastic) ,haven't had any bad/good things about them though,cheers
Old 06-21-2010, 02:14 PM
p-talk's Avatar
Delrin bushings will last longer against the inevitable leaks from an old car. I'm running rear poly sway bushings successfully with no noise, and I'll be installing Racer's Edge solid front bushings soon.
My recent thread on rear bar install (with make-shift poly bushings): My rear suspension upgrades
Thanks,
Justin
1984 Porsche 944 - Mathilda the needy
2014 Audi Allroad - daily driver
Old 06-21-2010, 02:41 PM
cjpacitto's Avatar
The delrin bushings will reduce body roll and improve handling.
They will also make the car a little harsher over bumps that only one side of the car hits.
It's all personal preference. I'm in Florida with (relatively) smooth roads and have no problems with delrin bushings and solid upper strut mounts. If I lived where the roads are crappy I'd rethink those decisions.
You should always add some grease to your bushings so squeaking should not be an issue.
Old 06-21-2010, 06:26 PM
I'm thinking about a replacement too...
Unfortunately I can't find the kit at a reasonable price.... shipping to Italy 35$ for these pieces... no kidding please!!
Anybody here can sell to me the kit??
Old 06-22-2010, 11:31 AM
