no spark
84 944s list of things already done,
new DME
coil
plugs
ref sensors
plug wires
ignition switch
checked fuses
rotor button
distributor cap
coil is getting power but from there none
stumped from there....
Old 06-26-2010, 08:29 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
do you have signal at the injectors? have you jumpered the dme to test the fuel pump function?
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 06-26-2010, 08:50 AM
no signal at injectors< yes about the fuel pump, getting fuel to the rail
Old 06-26-2010, 08:52 AM
89-944NA's Avatar
make a three wire jumper and jump the fuel pump to see if it is working. it could also be the dme relay, do you have a spare? Quite frankly, I am having a similar problem, I ran some errands the other day, and at my last stop (Porsche dealer), the car refused to start...had it towed home.
DME was just rebuilt (THAT is not the problem), checked the fuses, checked the relay, everything on the "won't start" checklist has been checked and still no start...now thinking it may be a faulty harness.
Also, one other thing to check..get under the car and have someone rotate the engine (slowly) and make sure the pins for the reference and speed sensors are still in the flywheel...I had one fall a few cars ago.
Good Luck, and keep me posted....I'll do the same for you.
Semper Fi
Old 06-26-2010, 09:02 AM
hey thanks for the info will try those things, will keep you posted
just checked with my mechanic, he said that the pins are good, leading toward wiring harness problem
Old 06-26-2010, 09:04 AM
89-944NA's Avatar
clean all the grounds?
Semper Fi
89-944NA's Avatar
search this list, there is a "no start" checklist posted, and begin the troouble shooting process....lol
Semper Fi
Old 06-26-2010, 09:05 AM
will do
Old 06-26-2010, 09:14 AM
89-944NA's Avatar
you amy also need to check the turbo postings for that checklist, can't remember exactly where I saw it
Semper Fi
Old 06-26-2010, 09:25 AM
