no spark
84 944s list of things already done,
new DME coil plugs ref sensors plug wires ignition switch checked fuses rotor button distributor cap coil is getting power but from there none stumped from there.... Last edited by jdb design; 06-26-2010 at 07:33 AM.. |
Location: In a dumpster behind Albertson's in Los Angeles County
do you have signal at the injectors? have you jumpered the dme to test the fuel pump function?
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ![]() 1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
no signal at injectors< yes about the fuel pump, getting fuel to the rail
make a three wire jumper and jump the fuel pump to see if it is working. it could also be the dme relay, do you have a spare? Quite frankly, I am having a similar problem, I ran some errands the other day, and at my last stop (Porsche dealer), the car refused to start...had it towed home.
DME was just rebuilt (THAT is not the problem), checked the fuses, checked the relay, everything on the "won't start" checklist has been checked and still no start...now thinking it may be a faulty harness. Also, one other thing to check..get under the car and have someone rotate the engine (slowly) and make sure the pins for the reference and speed sensors are still in the flywheel...I had one fall a few cars ago. Good Luck, and keep me posted....I'll do the same for you.
hey thanks for the info will try those things, will keep you posted
just checked with my mechanic, he said that the pins are good, leading toward wiring harness problem Last edited by jdb design; 06-26-2010 at 08:11 AM.. |
clean all the grounds?
search this list, there is a "no start" checklist posted, and begin the troouble shooting process....lol
will do
you amy also need to check the turbo postings for that checklist, can't remember exactly where I saw it
Thread Tools | |
Rate This Thread | |
