944 Susp. mods
I have an '86 944 NA. I need some suspension recommendations for AX. This is my daily driver and I am looking for some reasonable mods to be more competitive in my local PCA events...... like some Turbo sway bars and springs, or what have you that I can easily access.
Old 06-29-2010, 10:07 AM
the more u mod, the less competitive u are.
put in koni's, refresh the bushings, put on tires. drive it.
as of right now the slowest part of the car is you
Old 06-29-2010, 02:16 PM
That Guy
Techno Duck's Avatar
Check your regions rule book. Every region is a little different in terms of what they allow. The last thing you want to do is go into a modified class because you will be destroyed by the modified class 914's and early 911's.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 06-29-2010, 02:25 PM
Proprietoristicly Refined
John_AZ's Avatar
After you decide on the rules...
TECH FORUM General Suspension Preparation 924 944 968
Or, from 944S2.com
http://www.944s2.com/suspension/suspension.htm
HP & suspension:
http://germanautoforums.com/forum/showthread.php?t=7240
More advice
http://reviews.ebay.com/Porsche-944-968-Modifications-and-Repairs_W0QQugidZ10000000008344064
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 06-29-2010, 05:02 PM
racer's Avatar
What tires are you running? Even bone stock, ratted out suspension will go 1-2 seconds quicker on great tires
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 06-29-2010, 05:30 PM
Aslet's Avatar
If you run with PCA, the national parade rules allow a lot of changes on the suspension. I agree with Techno, check the rules of the group you are running with. Getting pushed into a higher class can screw you. Once your in a modified class, you will need to spend a LOT of money to be competitive.
-Randy
1984 944 -Race car project
1993 968 coupe- Amazon Green
Old 06-29-2010, 05:32 PM
Avatar's are to SMALL.
Send a message via Skype™ to cvriv.charles
If the rules allow it I have a set of 968 M030 sway bars in superb condition for $300 plus shipping. 30mm hollow front and 19mm solid rear. All hardware included. PM me if interested. I have a pic if you want.
1986 951 - Wrecked. Being used for engine swap and parts.
1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts.
Old 06-30-2010, 01:30 AM
cb951's Avatar
If starauto passes, I'd be interested in the swaybars. I'm also in NJ, so maybe a ride is in order. Thanks.
-Chris
'86 951 (daily driver with occasional DE)
Mods: A few.
Old 06-30-2010, 11:47 AM
jamesjedi's Avatar
If you are like me and like to build and tinker with what you already have, I suggest that you be patient in your purchases. You do not have to buy the best stuff, but you can buy great suspension parts at a very reasonable price.
Used Koni adjustable shocks are easy to find, I paid $100 for a pair. I paid $60 for 951 S sway bars. I paid allot for my new front Koni Coil-overs. And I spent $200 for 28 mm torsion bars. All in all it is not to expensive when you do the work yourself. The installation of the torsion bars is a BUGGER of a job.
Above all you do not have to spend big money to have fun, many expensive suspension mods are money down the drain unless you are a very good driver and have the money to burn. My fun does not come with a big price tag.
Something to keep in mind is that you will change the ride quality of the car. If you drive your car every day you will need to compromise on what you do.
Old 06-30-2010, 01:40 PM
I have a pair of non-adjustable koni yellows too. I dont know exactly how old or how many miles are on them but I know they are no more than 7 years old and at the max maybe 35000 max miles. I dont know what poundage the srpings are though. I measured the diameter of the coil and it measured 12.07mm. If someone could shed some light on what poundage this is? I'll give them away for $60 for the pair with the purchase of the 968 M030 sway bars.
Totally up to you.
Oh here are the 968 M030 swaybars:
Old 06-30-2010, 04:18 PM
944 Mods
Originally Posted by John_AZ View Post
Thanks a ton for the links, they are very helpful. I am fairly new to the 944 and i am on a steep learning curve. I have been doing A/X since 1974 and have also earned SCCA and IMSA licenses. My problem is that my region just throws all 924s, 944s and 968s into one class! When i showed up I had to run against Turbos on racing tires and so on. All I want to do is have some fun with my street car and not embarrass myself.
Old 07-14-2010, 09:14 AM
jamesjedi's Avatar
There should be a number on the springs. Eibach Race Springs (ERS) which are labelled by 3 different values in the following convention: length . diameter . spring rate. However, ERS will come labelled in either Metric (mm.mm.N/m) or English (inchx100.inchx100.lbs/inch) units. 180.64.61 is the same thing as 700.250.350. The conversion from Metric to English is (/.254, /.254, x5.7) "/" means "divide by", "x" means "multiply by".
In this case, I belive that 350=350 pounds. Please correct me if I am wrong.
Old 07-14-2010, 09:44 AM
kwikt 911's Avatar
How much for the rear bar only?? What size and how many holes?
Old 07-14-2010, 10:23 AM
"Dude! You kicked my car.
Rudeboy42's Avatar
I'm pretty sure every region puts all front engine models ,except 924's, in production02. As for the racing tires that shouldn't be allowed in a stock class.
Just remember autocross courses are tight and turbos take time to spool up so since the NA has shorter gearing you almost have an advantage. Last time I did autocross I ended up beating a guy who had a 944 turbo with a k26/8 turbo (which is a big turbo).
You're very experienced so just get some good tires and a decent suspension set up and I'm sure you'll do fine.
Old 07-14-2010, 10:01 PM
racer's Avatar
My local PCA uses one of the "small" or "mid region" PCA National classing guidelines. As such, ALL 924S, 944, 944S, 944S2, 944T, 944TS, 968 and 928 run in the same class.
Our region calls it P3 I think. It allows for a lot of "street prepared" type allowances.. like R comps/Hoosiers for one, upgrades springs/shocks for another.
With only 150hp, it can be tough, but not impossible to do well, depending on course layout. I tease the S2 guys that I beat because heck, I am spotting them 50hp and their larger brakes, stiffer suspensions etc.
Like someone else said, Check the rulebook to see what mods you can do for the class you want to run in.
That said, is possible that a well prepared PCA car will NOT work for SCCA (where the 944 is an E-Stock car, and mods are limited)
Past:
Old 07-15-2010, 07:10 AM
