The guy making faces
tomamafone's Avatar
Send a message via AIM to tomamafone
Please Help! Coolant/heater system failure!
Hi Guys,
I had an overheat situation in the Drive through of a taco bell (lots of idling). Steam everywhere no cooling happening.
I checked it out today expecting to see coolant leakage out of the front of the engine. To my surprise when the car got up to temp, the steam came from the rear of the engine. It's coming from a hose that originates at the firewall on the passenger side and travels to a port just on the drivers side at the back of the engine. I cant quite tell where it's supposed to be going.
Does anyone have a picture of the engine from the back?
What is this hose and where is it going? It looks like the nipple sheared off.
Has anyone had this happen?
What piece of metal is this attached to?
Can it please be inexpensive?
Here are some pics:
And I dont know if this is where it came from or if this is the view port for the flywheel but here it is anyhow:
Thank you for your help!!
Tommy
Tommy
'88 944 "Mona" the new Daily Driver
'75 1.8L 914 "Seraphina" sold and becoming a V8 Race Car!
'88 BMW 325i "Rodney" Sold and well taken care of
Old 07-19-2010, 06:07 PM
Looks like the hose that connects to the bottom of your heater control, the white plastic saucer shaped valve in your thrid picture. The valve is not expensive but is a little challenging to replace. Kinda tight working in there.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 07-19-2010, 06:16 PM
tomamafone's Avatar
Oh please be a plastic something... Challenging I can do. Im still afraid it's an aluminum nipple...
Tommy
Old 07-19-2010, 06:20 PM
I know what you mean but the volcano burrito is worth the pain.
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 07-19-2010, 06:30 PM
tomamafone's Avatar
HAHAHA! Thank you. I needed that.
Tommy
Old 07-19-2010, 06:38 PM
That looks like the heater control valve and the entire thing is plastic & replaceable. It's $17.50 at Pelican.
It's actually got a hose connected to the bottom and the top and also has a small vacuum line connected to it.
Old 07-19-2010, 08:27 PM
tomamafone's Avatar
Question for you (or anybody). Can that be plugged up as a band-aid so i can drive the car in the meantime just without the heater or would blocking that line cause damage?
Thank you!
Tommy
Old 07-20-2010, 01:19 PM
Nissan has one for about $20 that is all metal and does the same function.
Good luck, George Beuselinck
Old 07-20-2010, 01:57 PM
u'd have to plug both sides. which means gettin in there and removing the valve and plugging both hoses.
blocking the line is what the valve does. heh
Old 07-20-2010, 01:59 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Looks as though the metal "nipple" as you call it is alright, just take the stub of hose off and replace the hose. It doesn't appear from you pictures that the valve has broken, just the hose from block to the heater valve. Tight fit is NOT the word for it, it's a knuckle scrapper. Check the valve to make sure the bottom inlet is intact before you go and buy a new one.
The hose is available from pelicanparts under the number 944-572-385-01-M101 at $5.25, the heater valve is part number 928-574-573-03-M53, and it's also at pelican for $17.50.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 07-20-2010, 04:35 PM
p-talk's Avatar
Hmm, more details on this all metal Nissan part?
1984 Porsche 944 - Mathilda the needy
2014 Audi Allroad - daily driver
Old 07-20-2010, 04:52 PM
tomamafone's Avatar
Thanks a million times! The part numbers made it that much easier to find
I've attached pictures of the broken part to satisfy the curiosities!
Tommy
Old 07-20-2010, 06:43 PM
