mr5296's Avatar
Flex plate line up
Hey, I would like to get some advise when installing the damper plate. I got it all done but for some reason when I go tobolt the damper plate to the flywheel the bolts dont line up.So can someone give me a little guidance into how i can get this all lines up, thanks
86 guards red 944 NA
Old 09-03-2010, 11:09 AM
Toofah King Bad
Rasta Monsta's Avatar
Can you have an assistant turn the engine via the crank bolt while you watch underneath for alignment?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-03-2010, 11:33 AM
mr5296's Avatar
yeah i figured it out, just had to take off the bellhousing a third time, since i like dropping bolts in the sensor hole, and just lined up the motor timing marks with the plate
Old 09-05-2010, 10:31 AM
