Fixing rattling cat converter
My cat started rattling, dang. And at 2700 rpm right where i drive most the time. Anyone have a pic of what these look like inside, are they the honey comb type? I was thinking of drilling some small holes and pushing some steel rods up in there to put pressure on the broken sections and then weld them in place, to try and compress it together again so it does not rattle around. Would be a quick experiment in fixing the dang thing.
Any ideas, input or pics of the internals of this thing? It's a 86' stock cat.
I like them I drive them |
yarfk
Info: ******** Parts Catalog
------Keith------kfray------yarfk------- 87 944 NA stock 116k 06 Honda Ridgeline 83k 10 Vibe 2.4 AWD (Wife's) Retired My week consist of Saturdays and Sundays
Custom User Title
Here's a recent thread on that: Gutted the S2 cat
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
Location: In a dumpster behind Albertson's in Los Angeles County
Are you sure the rattle is coming from inside the cat? I found my rattle to be the upper heat shield on the cat had come loose.
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
Going faster all the time
just replaced my cat, but still got a rattle at almost exactly 3250 (indicated) RPMs. Stays as long as I can at that Rev... disappears immediately after or before...
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
I tried pressing on the heat shields when the rattle was happening to see if it was the shields, did not seem to help. I actually want the cat working because it really makes a diffrence in the fumes. I hate driving behind a non cat car smells terrible. My 911 is a carbs only car and wow, so stinky, kinda feel sorry for the guys behind me on hard drives.... Ill see if my method works and also start looking for a good used one
Hit it with a rubber hammer and see if it rattles, if so replace it.
You really can't FIX a converter once the substrate has broken up.
Rick 93 968 (My summer car), 05 Cayenne S (My winter car), 79 924 (Wife's summer car), 02 C230k (Wife's winter car), |
Good advice 968rz, ill do that.
jim brown
check your o2 sensor and make sure its tight , I had the same problem replaced the cat and still rattled turn out sensor was loose about a 1/2 a turn !
