Wining sound from engine, alternator?
I have just started getting a wining sound for the engine bay coming from the direction of the alternator. Just had the water pump belts etc replaced. Could the mechanic have tightend the belts too tight ruining the alternator bearing
Thanks, Waxman 1990 944S2 |
Yes. Or something is being pulled out of alignment and the belt is rubbing.
1983 944 - project mode 2002 Ford F150 - every other daily driver 1976 Honda Goldwing - the other days |
Can the bearing be represssed or does the Alt have to be replaced, Alt replace in 2004
Thanks |
Proprietoristicly Refined
Does it sound like this-------move to 2nd last page of link and click on video of "too tight balance belt"
http://www.arnnworx.com/tensioningbelts.htm GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
There are too many possible causes for the info given. Take it back to the mechanic and have him fix his work. If you were choosing to let a mechanic do the belts before, you are going to have to go back to him anyway to fix this. If you try to fix it yourself or wait too long he might not want to do it without charging.
The sound in the video "too tight balance belt" is the noise. The mechanic that did the work is no longer in the area (surprise) but I will find anotherand get it fixed
Thanks |
