stray15's Avatar
Send a message via AIM to stray15
Need help from Electical GURUS
I am trying to find out why my heater blower does not work. I have the blower unhooked from the car and am wondering how I can/should test to see if it works. Here are the pics of it:
PS, I need help right away, it is supposed to start snowing any minute now and I have no garage . Thanks guys!
Old 01-06-2002, 08:54 AM
OK.
You need (at least) two test leads (wires with an alligator clip on each end). Clip one to each blade in the connector and ground one to the car chassis. Take the other one and tap the positive post of the battery while holding the motor to keep it from taking off on you due to torque. If the motor is good, it will spin. If it is dead, it will not.
If you have access to an ohm meter, simply taking a resistance reading across the motor leads will tell you whether the motor has an "open" (broken wire). If this is the case, attaching it to the battery won't do a thing.
I will be the motor is OK.
Let us know
Cheers
Bob S.
Bob S. former owner of a 1984 silver 944
Old 01-06-2002, 09:02 AM
stray15's Avatar
Ok, right now my battery is totally out of the car. Since it is out, should I just hook one lead to each of the poles, or should I put the batter back in the car and try like you said?
Either way, does it matter which one goes to which?
Old 01-06-2002, 09:16 AM
If there is two leads, one to each pole on the battery should work. If a lead is brown, hook it to battery - .
drew1
Old 01-06-2002, 09:23 AM
Roger Hall's Avatar
It souldn't matter wich lead you conect to the positive and negitive on the battery. If the blower doesn't start just switch the leads. Have you checked the switch and relay? They are eiaser to get too and they are more likely the cause.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 01-06-2002, 06:51 PM
AFJuvat's Avatar
It isn't too often that the blower goes out on these cars according to the dealer, they have only seen 2 that were actually dead motors - check the fresh air blower relay (I think it is #15 on the 85.5+ cars)
AFJuvat
Old 01-07-2002, 02:10 PM
