Random Question about Empty gas light
This is just a random question.
Once the E light has come on the gas guage. How long of travel do you have left in gas if you were to drive with care? If you know what I mean lol.
88 944 2.5L 4cyl NA Zermatt Silver CE - Daily Driver - SOLD |
You shouldn't run your car that low on gas. All the junk from the bottom of the tank will get sucked in and ruin your fuel pump.
IIRC its a few gallons. Last edited by RedBaron; 08-22-2010 at 03:44 PM.. |
Proprietoristicly Refined
The "reserve fuel capacity" is 2.4 gal.
The problem with a 23 YO car and the dash fuel level guage is the calibration of the fuel tank sender. Yours could be off a gallon----up or down. The contacts TO wires on the fuel tank sending float could be dirty and give a false reading. BTW, there is a $45 fuel tank strainer in the tank that block the big chunks before they get to the fuel pump----------unless the strainer has rips in it like my '87 had. ![]() GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Porscaholic and loving it
From what I've experienced (TWICE
![]() But those are just my personal experiences :P
1984 Maroon PORSCHE 944 (Sold: Nov. 19th, 2011 ![]() 1974 Sky Blue DATSUN 260Z PORSCHE
My anti-drug <3 |
All Spooled Up
My 89 951 will start sputtering before the low fuel light comes on. But then, the gauge will only go up to 3/4 tank. Need to fix those bad grounds.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
Redline Racer
I've gotten maybe 30-40 miles without any problems and never actually reached the sputtering point, but I believe my car has the early tank. IIRC, the late tank has a smaller reserve capacity. The crap is going to be at the bottom of the tank where the pickup is no matter how much gas is above it, so the level will make no difference in that respect. Just make sure you have a good strainer. Your mileage may vary due to calibration/corrosion/grounding issues.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
alright thx! yeah, it was jus a random question :P
Per the manual if all is working properly...
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS |
Coming up on your left...
Ever since I owned my car, it only seems to fill up to about 3/4 capacity.
Not a big deal to me, as the car still has a relatively large tank at that (it takes about 16 gallons). Doesn't leak fuel and my gauge is relatively accurate I think. I did run the car super low one time, as I thought maybe the gauge itself was the culprit. However, the light stayed on and the car seemed to starving for fuel a little so I do think that the top of my tank is "inaccessible." I wouldn't go more than a few miles with that light on. What gives? Weird problem, if you ask me.
1986 Porsche 944 Turbo "S" clone ![]() 1998 Honda Accord ![]() Siena College '08 Manager, Mavis Discount Tire ![]() |
repost
Older fuel gauges were not the most accurate or reliable in the world when they were new. Add a quarter century and how well do you think they work?
If you are running on low fuel where the pick up is getting anything but a 100% constant stream of fuel, you can damage the fuel pump (already mentioned) and more expensive and maybe more sensitive to this your fuel injectors. Both of those use the fuel to lubricate their moving parts so you are causing damage well before sputtering. Would you keep running your engine if the oil pump was sucking air and losing pressure? Same concept here.
1983 944 - project mode 2002 Ford F150 - every other daily driver 1976 Honda Goldwing - the other days |
