winter-hater club member
nynor's Avatar
so, to recap. you had sand in your tank but were getting proper pressure and flow from the fuel pump.
but now, you've cleaned it all out but the coil is bad.
"COOL PRIUS!" - Nobody Ever
Old 09-29-2010, 09:50 PM
85 porsche 944
yes that is correct. but im about 100 % sure,, the sand made it to the fuel injectors and only one is opening.
Old 10-01-2010, 01:46 AM
nynor's Avatar
that would do it.
Old 10-01-2010, 07:46 AM
85 porsche 944
what would make my car loose injector pulse?
Old 10-01-2010, 05:31 PM
nynor's Avatar
bad dme, bad dme relay, broken timing belt, i am sure there are more options.
what makes you think you aren't getting signal to the injectors?
Old 10-01-2010, 07:20 PM
Are you getting tach bounce?
I'm trying to figure out why I'm not getting signals to open the injectors also. I can open them up manually and the car will run. The stuff I've done is in this thread: Can I generate fuel injector signals? Do I have a bad DME?
Old 10-01-2010, 07:34 PM
CPR CPR is offline
The Splitter Maker
CPR's Avatar
I am a little lost here.....you checked the strainer and it was clean, yet you have sand in your tank? Plus you changed the fuel filter, and noticed no sand?
Something is strange.....
PATRICK
Built fast to last with:
CPRacing~Vitesse~PowerHaus~FabSpeed~TiAL~NiTTo
Old 10-01-2010, 08:28 PM
nynor's Avatar
troll?
Old 10-01-2010, 09:00 PM
85 porsche 944
what makes me think i aint getting signal is that im gettin proper amount of gas pressure to them, i can spray car cleaner in the throttle boddy and it runs. but when u first start these cars all ur injectors open at the same time for the start. but after it starts and the key is moved to ac than they open at seperate times. i think that there just not gettin a signal from the dme computer. but i think what may cause this is a bad fly wheel sensor but im not totally sure. what do u all think?
Old 10-03-2010, 06:04 PM
85 porsche 944
and for the sand thing, at one point i did have everything good in the tank and fuel lines, but, somehow, my fuel pressure droped when i was still workin on it. some1 put sand in it while it was sittin around. just my luck lol
Old 10-03-2010, 06:05 PM
85 porsche 944
ok, now my starter isnt gettin signal to turn over, it works and iv had it off to test it. is it possible that my speed or refference signal sensor have anything to do with this or any other problem iv been having?
Old 10-04-2010, 05:51 PM
nynor's Avatar
ignition switch.
Old 10-04-2010, 05:59 PM
85 porsche 944
put 3 new ones in it. still does the exact same thing
Old 10-04-2010, 06:03 PM
nynor's Avatar
three new ones? where did you get three NEW ones?
relay. wiring. fuse.
Old 10-04-2010, 06:08 PM
85 porsche 944
auto zone here where i live can special order them.
Old 10-05-2010, 03:57 PM
Porscaholic and loving it
Ez-Bone's Avatar
Send a message via AIM to Ez-Bone Send a message via MSN to Ez-Bone Send a message via Yahoo to Ez-Bone Send a message via Skype™ to Ez-Bone
Porsche Crest
Originally Posted by Slam View Post
Three checks in addition to looking for vac leak: DME temp sensor, stuck AAV (auxiliary air valve), O2 sensor. These three things will affect cold starts if they're not behaving themselves. If you can start it and keep it running on the throttle, I'm guessing the AAV is stuck - closed probably.
These issues are annoying, aren't they?
Hey, I'm bascially having the exact same problem. However When I try to throttle mine, it dies. And actually I don't even need to touch the throttle and it will die.
What things could be associated with that?
Originally Posted by mikepellegrini View Post
If that's the case, can you confirm that the pump is actually running?
You should try checking the pressure - Fuel Pressure - Checking
Here's the procedure for testing the DME relay: DME Relay Information and Testing
Do these pumps activate when the key is in the 'on' position or when the engine actually starts cranking?
I test mine and the pump didn't activate till I started cranking the engine. I had the fuel feed off and aimed into a can and as soon as I crank the engine, fuel started gushing out. Is that normal or should the pump energize prior to cranking?
1984 Maroon PORSCHE 944 (Sold: Nov. 19th, 2011 )
1974 Sky Blue DATSUN 260Z
PORSCHE
My anti-drug <3
Old 10-16-2010, 06:49 PM
nynor's Avatar
i think it doesn't start the fuel pump until the engine is turning over. it is a safety feature that prevents the pump from running on in the event of an accident or other failure.
Old 10-16-2010, 07:16 PM
85 porsche 944
well, after i tried everything, i replaced the dme computer. the thing runs perfect. i guess it was the problem all along. but i do thank everybody that has gave me avice. u guys have been absolutly a great help to me.
Old 10-17-2010, 07:10 PM
nynor's Avatar
bs. the DME has nothing to do with the starter.
Old 10-17-2010, 07:22 PM
