-   -   Knocking when turning - AC compressor? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/567224-knocking-when-turning-ac-compressor.html)
Born2bwild1191 09-30-2010 05:24 PM
When I make a quick right turn, or a hard right turn, I hear a knocking noise. It sounds like a sway bar bushing, but it isn't. I noticed my AC compressor is actually sitting on top of my sway bar when I looked under it. It looks like it could be the problem and seems like it is the general location the sound is coming from. Is this normal?? Everything is tight, I can't figure it out
nynor 09-30-2010 05:30 PM
is your car lowered?
it sounds like your AC compressor is too low, or the sway bar is too high. can you get a picture of this to post?
Born2bwild1191 09-30-2010 06:12 PM
Nope not lowered. I agree that's what it seems like. I'll try to post a pic tomorrow. Does anyone have a pic of the normal underside that I could compare to?
nynor 09-30-2010 07:04 PM
http://1.bp.blogspot.com/_LvxjhxOrHgc/TDcfIzyYvBI/AAAAAAAAAPk/_Zc5h1HCdXI/s1600/S1050195+%5B50%25%5D.JPG
http://1.bp.blogspot.com/_LvxjhxOrHg...5B50%25%5D.JPG
nynor 09-30-2010 07:05 PM
do you have an aftermarket swaybar setup?
Born2bwild1191 09-30-2010 07:19 PM
I do not. Mine is a 951 though, looks a little different from that pic. My compressor has two lobs on it, one which the tensioner connects to and the other has nothing connected to it. This is the one that is touching the sway bar.
nynor 09-30-2010 07:28 PM
ya know, that picture doesn't look right. i think that is actually the alternator. let me try again with the pictures.
porsche4life 09-30-2010 07:29 PM
That car HATH no AC!
nynor 09-30-2010 07:35 PM
sorry, i cannot find another, better picture. but yeah, i think this car has the alternator in the AC position and a shorter ribbed belt.
Born2bwild1191 10-01-2010 01:42 PM
Here's my pics. The lobe of the AC is actually resting on the sway bar. SOrt of bad pics because I didn't have time to put it on the lift but you get the picture....My dad seems to think the belt is too big/stretched and it needs replaced and tightened.http://forums.pelicanparts.com/uploa...1285965689.jpg
http://forums.pelicanparts.com/uploa...1285965707.jpg
http://forums.pelicanparts.com/uploa...1285965722.jpg
nynor 10-01-2010 03:07 PM
are you sure that compressor is attached at the mounting point? that definitely looks wrong to me. the belt tensioner is much more horizontal on my 951.
ernie9944 10-01-2010 03:48 PM
Was wondering the same ,there is definitely something that doesn't jive here seem to be lower in the rear then in the front.this is my 968 but your should be the same, has you will notice there is quiet a bit of clearence dind't measure but at least 2" between the rear lob & the sway bar & this is an m030 bar.http://forums.pelicanparts.com/uploa...1285972911.jpg
ernie9944 10-01-2010 04:07 PM
:eek:Sorry got it wrong the pic was taken with the car jack -up hence so much clearance ,when sitting they should be be approx 3/8" to ½" from the front of the rear lob to the sway bar,your's should be a little bit more unless you got the m030 SB on it.
mattdavis11 10-02-2010 08:36 AM
Either the ear broke off the rear of the compressor, or the bolt backed out and is gone. There are two different compressors pictured above, the early cars have a 6E171, the later cars have a 10P15E. Both are Nippondenso compressors.
Born2bwild1191 10-02-2010 10:26 AM
My compressor is the same as the one Ernie posted - I have a 951 so it's a late model. The lobe in the back doesn't have anything connected to it (and never did) and I'm not sure what that would do even if it did. The front lobe has the tensioner connected to it, that's it.
mattdavis11 10-03-2010 03:50 AM
Whoops, Ernie pictured his 968, yep same compressor. There has to be a through bolt on the rear of the compressor. The head on it is 15mm and the retaining nut is 17mm, I forget the length. Although rare, the bolt can back out and vibration can cause the ear to break off. This generally happens when someone forgets to tighten things after they tension the belt.
If you are telling us that there is no way to mount the compressor other than by the tensioner, your ear has broken off and the nut and bolt are gone. It's time for a new compressor.
Born2bwild1191 10-03-2010 05:49 AM
Ahh you're talking about the mounting ear? It's mounted OK. I thought you meant the ear that was actually hitting off of the sway bar should have a mount connected to it, hence the confusion.
Born2bwild1191 10-20-2010 11:45 AM
Hate to bring this back up - Replaced the belt and the AC compressor is where it should be now, but it's still making a noise when I turn. I looked at everything underneath and can't find anything loose, anybody else had this problem?
smokin_944 10-20-2010 12:02 PM
Are you sure the sound comes from the front of the car? Nothing should be in contact with the swaybar. I run an 030 setup and have lots of room. If the sound came from the rear I would definitely hazard a guess...
looneybin 10-20-2010 12:18 PM
i have had that same klunking issue when turning right, and going up a drive approach.
It was a loose sway bar bracket
check the 2 bolts that hold the sway bar bushing to the vertical bracket to make sure it's tight, mine was slightly loose & when the sway bar twisted with the right wheel being compressed in it's travel up & down it would make a nasty klunk.
