James Chimney
setting the idle
I have an 85.5 na and took the "yellow cap" next to the throttle cam off and there is a raided pin over a 6 sided bolt, I can not get a socket to fit so I used my needle nose and turned this nut, did nothing to the idle. am I in the right place?
thanks
Old 10-13-2010, 03:19 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Yes, that is where you adjust the idle. But there are a few steps you need to do before you can properly reset the idle.
Located in the engine compartment in front of the fuse box, there is a black flat covered "plug", you need to jumper the plug to put the idle stabilizer in the center position. Then you set the idle and remove the jumper.
Instructions for properly setting the idle can be found here (same instructions apply to the NA cars):
IDLE SETTING 944 T at LINDSEY RACING - Your Porsche Performance Parts Center
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 10-13-2010, 04:54 PM
P944GUY's Avatar
7mm small socket fits that screw..
Old 10-13-2010, 06:12 PM
89-944NA's Avatar
narrow flat blade screw driver works wonders
Semper Fi
Old 10-13-2010, 07:04 PM
