Send a message via AIM to sempaipaul
.. I guess a barn find is what you call this...
Hello everyone,
Well I have come across a free 1987 Porsche 944 Automatic :/. Either way, the car, has been sitting for 5 years in one spot. I know that it needs new brakes, rotors, all fluids (oil, coolant, power steering, brakes), needs new battery...
This brings me to a few questions.
1. How do I drain (and to where) the old fuel that is in the tank? yes it has been there for 5 years, I dont know how much of it is in there yet, as the battery is absolutely dead, and I need to replace it, or maybe recharge?
2. What other things should I look at before I attempt to fire it up again?
Thanks for help!
-Paul
03' Audi RS6; 16' 328i xDrive Touring; 13' X3 mSport, 91' e30 M52
Old 11-16-2010, 01:23 PM
Paul,
Congrats on the find.
I would like to navigate you to the following site for us DIY'rs..click under the garage shop manual.
Clark's Garage Home Page
Alex
Old 11-16-2010, 01:53 PM
ernie9944's Avatar
All you mention above is the least of your worries rigth now,since the car has been sitting that long (Timing belt -Balance shaft belts as to be check & done ASP .Because if you do as much as turn the car over they migth breake & you'll end up in a mess(specialy bent valves) ,damage to the head could be very costly.Then once that done you can think about (oil -fluid ect ect).
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 11-16-2010, 02:00 PM
Proprietoristicly Refined
John_AZ's Avatar
Automatic Flex Damper is KaPut--Cracked--Ruined--$1200 for parts ++++
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 11-16-2010, 04:03 PM
GL
John
sorry complete noob...
what is that?
Old 11-16-2010, 05:38 PM
many barn'd, garage'd, forgotten 944 automatics were set aside due to the flex damper failing....think of it as a big rubber disk shock (torque) absorber (that costs $1200) between the transmission and the engine....and imagine its condition after all these years.
Old 11-16-2010, 05:57 PM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
Perfect time to do a swap
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 11-16-2010, 07:21 PM
