Send a message via AIM to hpaulb
Engine blocking
Anyone know of a cheap way to lock the engine so I can do a leak down test? I don't want to order a single part to Canada just for that. Or anyone want to sell one?
Put a replacement engine in a short time ago and did a head job and it's using a lot of antifreeze. Suspect a crack in the head gasket. Crap!
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 11-04-2010, 07:44 AM
just put socket and a tbar on the the crank bolt and wedge it against something?
Old 11-04-2010, 07:52 AM
unindicted co-conspirator
looneybin's Avatar
you could put it in 5th gear and chock the wheels
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 11-04-2010, 11:55 AM
Redline Racer
HondaDustR's Avatar
I like the breaker bar on the crank bolt idea if you don't have a flywheel lock.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 11-04-2010, 01:14 PM
Capt Squid's Avatar
As several have stated, a breaker bar on the crank bolt is the hot ticket. Have someone hold the bar while you do the leak down. Warm up the engine before the leak down test.
Jim Richmond
944 Spec race car, SoCal NASA & POC
01 Boxster S
Old 11-04-2010, 08:07 PM
