Performance Chip
I bought this chip and installed it
88 944 2.5L 4cyl NA Zermatt Silver CE - Daily Driver - SOLD |
Redline Racer
I highly doubt it gains as much as the ad says (and there is no top speed limit on 944's), but that's great it works. Even the best 944 chips will gain maybe only a few hp up top, but the gains are usually found in the midrange and part throttle, kicking the lazy factory ignition advance up a notch. Good deal, too. It's more than likely a copy of one of the several good chips out there.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Yea i was supprised that this chip performed well. For 40$ its worth it! I had to do research to make sure it fit my ECU. Taking the ECU apart scared me because I didnt want to break it! I notice my 0-9 went from 10sec to about 9. I also noticed I can spin out easly now. +1
Porsche 944S Club Sport
Also recommend Ignition Coil Upgrade, MSD Blaster 2 for ~$45 is worth more Torque and Power throughout rpm Range.
Suggest Retune for Max Efficiency after 200miles... Cool....
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
