overkill's Avatar
Send a message via AIM to overkill
I need a quick responce ! ! ! ! When draining the cooling system...
the car should be flat(not on ramps)? Does it matter seeing that it has to be flushed til clear?
{1987}944S - (SOLD).
Old 02-01-2002, 06:44 AM
AFJuvat's Avatar
Flat is fine. open the radiator drain, and let the coolant drain out.
If you want it to drain faster, take the cap off the expansion tank.
AFJuvat
Old 02-01-2002, 08:33 AM
