Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Thumbs up Highest HP& Tq using K26-8 Turbo vs K26-6
Guy's and Gals:
Just wondering, what are the greatest power attainable from the Stock K26 Turbo's? I'm looking to upgrade my 16V for more power using the K26 Turbo's I have a K27 for rebuilding also for consideration, but not sure . It's going to be a low pressure system running to 4-7psi due to my ~11:1 compression.
I know there is a ~ 30hp difference at between the 86-88 Turbo and the Turbo-S 88/89 vehicles stock.
Please feel free to post dyno's for visual references or PM Me.
Thank you in advance
Later
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 12-26-2010, 05:07 PM
Endat's Avatar
Subscribed. Im sure it's more on a DOHC platform..
Old 12-26-2010, 05:15 PM
guru944's Avatar
Does the Turbo S run more boost than 11psi on the K26-8?
Just wondering???
Any response would be greatly appreciated, Thanx.
Guru944
Old 12-29-2010, 04:37 PM
Endat's Avatar
I think it runs the same boost on a larger compressor giving more cfm.. im probably wrong though
Old 12-29-2010, 05:21 PM
All Spooled Up
Same boost & same compressor as -6, but larger turbine. Provides more power at top end of rpm range.
K26/8 is at top of it's limit around 330 or so. But you need to run like 20psi (in a low comp engine) to see that.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 12-29-2010, 07:40 PM
guru944's Avatar
Latest info:
The compressor wheels on K26-8 is 46mm Ex and K26-6 is 44mm and also Turbine Exducer on K26-8 is 55mm Vs 48mm on the K26-6.
The K26-8 tops out at 350hp at 17.64 psi while the K26-6 ends at ~310 around 18psi...
Looks like the K26-6 spools up around 300-600 rpm sooner.
Looks like a K26/27-6 is the way to go... for more flow and good drive-ability all around...
What do you guys say?
Good topic though.
Later.
Guru944
Old 01-01-2011, 09:18 PM
guru944's Avatar
I mean more like the K27-6 Right?
Later.
Guru944
Old 01-01-2011, 09:20 PM
