oil presure
on cold stard my oil presure is hi +- 7 bar and as the engin is geting hot it drops to 2 bar is it normal ?
Old 01-02-2011, 02:56 AM
carsonmx114's Avatar
I think you're fine. Colder oil is thicker so the pressure is higher. Hot oil is thinner so the pressure is lower.
86' 951
k26/27 hybrid turbo
01' audi s4
98' TDI jetta
96' 933tt AWD LS1
Old 01-02-2011, 07:08 AM
Mine pegs at 5 bars at idle when cold. It stays at 3.5 bars at idle when hot. Oil is Mobil 1, 15-W50. Engine has 180K miles on it.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 01-02-2011, 07:32 AM
Redline Racer
HondaDustR's Avatar
Yeah, that's about right. I'm running 0W-30 for the cold weather and it pegs at startup, but gets there ALOT quicker on sartup in cold temps that the Brad Penn 20W-50 that was in there. It holds a solid 2 bar at idle once warmed. I like the 30 weight for the winter, but may keep it for the summer depending on how it does. Hydrodynamic bearings don't need pressure to work, they need flow to stay cool. As long as there's enough pressure to ensure good supply to all the bearings (~10 psi per 1000 rpm), thinner is better since it will flow more and cool the bearings better at higher rpm. Formula 1 motors run 10 and 20 weights and they'd have to to make the bearings last at 18K rpm. 25 year old production motors don't have the bearing clearances needed to be able to hold enough pressure for oil that thin, but the principle is the same. That 50 weight opens the OPRV at 2500rpm and after that, that's all the flow the bearings get. The rest goes out the OPRV into the sump, since 50 weight can only flow so fast through very small bearing clearances at 4.5 bar. The more easily the oil flows, the better, as long as it doesn't go too thin and drop pressure.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 01-03-2011, 11:10 PM
All Spooled Up
Seven bar seems kinda high. Isn't the OPR valve supposed to open at somewhere around 5bar? If I crank my 951 in cold weather (using heaving oil) with the coil disconnected, it first spikes up to 5bar. Then it settles back to just over 4 and remains there. After being started, it stays between 4 and 5 bar, no matter what the rpm.
Old 01-04-2011, 05:31 AM
ernie9944's Avatar
My 968 oil pressure on initial start up with 20w50 & after a hard run idling at 1100 rpm if idle come down to 950 after a hard run oil pressure will settle at 2- 3/4 bar agree with__wild man__ 7 bar will be a little higth.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 01-04-2011, 08:18 AM
ernie9944's Avatar
Correct me if I'm wrong but I don't think any 944-951-968 has pressure gages witch are grade to 7 bar. Usually there are from 0 to 5 bars.
Old 01-04-2011, 08:29 AM
Redline Racer
HondaDustR's Avatar
I thought so, too, but came across this in a 83 944 manual pdf that shows the old 924 10 bar gage. Personally, I'd rather have the 10 bar gage.
Given how the 5 bar gage pegs on cold startup, it has to be at least more than 5 bar on startup. The OPRV opens at 4 bar, but when the oil is cold it still can't flow enough wide open to regulate the pressure with thick oil. 7 bar sounds about right for winter starting, and is definitely too high for operating temp.
Old 01-05-2011, 12:26 PM
yes it is a 1982 924 . same as pick . i did chance the motor 2.2 5 cylinder but it hafe all the origenal presur sender units . i'm from south africa and porcsh parts are pricy hear . the conversion same cost than 2 neu pistins for the old motor.
and it is runing mutch beter with the 5 cyl motor
Old 01-06-2011, 07:33 AM
I'd like to see pics of your car... and your engine swap.
86' 951
k26/27 hybrid turbo
01' audi s4
98' TDI jetta
96' 933tt AWD LS1
Old 01-06-2011, 07:41 AM
hi hear is some pics . it stil need som tidy up work .
Old 01-06-2011, 08:48 AM
Toofah King Bad
Rasta Monsta's Avatar
Originally Posted by HondaDustR View Post
Personally, I'd rather have the 10 bar gauge.
Yeah, that is JUST what you need, man. . .one more thing to fret about.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-06-2011, 10:59 AM
