Scott R's Avatar
How do I permanently disable the brake pad warning system?
I just replaced the rear sensors today to ket that Damn waring light off, and it stayed off for a few seconds, then the next bump I hit it went on again!! So how do I disable it? Can I tie all the leads together? Can I dosconnect something? I can't stand that red light for another minute!
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-16-2002, 03:54 PM
That system is a closed loop and any break in it sets the light off. So you could just cut the wires at each wheel and solder them together.
Knowing that it is a closed loop you also could probably track down where the break is and fix it.
Old 02-16-2002, 05:08 PM
Scott R's Avatar
Thanks!!!! I would rather just loop them then deal with these cheapo sensors anymore!
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-16-2002, 05:22 PM
