Speedometer not working
When I bought my 1986 944, the speedometer and odometer were not working. I was told it was the cluster and that it came with a spare turbo cluster. I swapped the 2 of them and when the turbo cluster was in none of the gages worked. So I checked the fuses checked the wires and changed the impulse sensor and still the speedometer and odometer won't work. I know the odometer could be the gear but what could the speedometer be?
Old 02-16-2011, 09:28 AM
Anyone know?
Old 02-17-2011, 06:47 AM
DAM0's Avatar
924.ORG FAQ
Old 02-17-2011, 09:03 AM
944sracer's Avatar
Is the speed sensor installed? Functional? Hooked up? It's on the tranny drivers side.
89' 951 Turbo S Race Car - SP-3, PT-B
87' 944 Diamond Blue Metallic - DD
"Practice does not make perfect. Perfect practice makes perfect" - Ross Bentley
Old 02-17-2011, 11:48 AM
Yes the speed sensor is called the impulse sensor I belive.
Old 02-17-2011, 11:55 AM
968 GUY's Avatar
Are your connections at the rear of the cluster seated firmly? Are the locking tabs broken off?
If they are, you may be getting them caught between the plug and the socket, or, not locking in and pulling loose as you replace the cluster.
A couple of my lock tabs are broken and I have to make sure they actually lock in.
Which reminds me, my speedo in the 6- speed 968 (has the broken tabs) stopped working for a minute yesterday... til I gave it the ol' "technical tap". Need to check those connections.
Also, I have at times, been able to reach up under dash and behind cluster to lock in a tab, but it is a bit tight.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 02-17-2011, 10:11 PM
Not sure if it's the same as the 968, but I had a problem with a bad connection on the ABS sensor plug at the left front wheel, which resulted in no speedo or odometer reading.
Old 02-26-2011, 11:15 AM
ernie9944's Avatar
Originally Posted by DAM0 View Post
The speedo on a 86-944 is not driven from the left front wheels ,why the link to 924.org?
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 02-26-2011, 12:21 PM
Mine was the sensor on the transmission, it looked fine visually but when I put my hand on the wires to check the connection the whole unit was loose, in two pieces. Bought a good used one and it works now.
Be nice if it is that simple
Rusty
Old 02-26-2011, 08:08 PM
