944 Rear Main Seal Advise
Just purchase a 8 NA w/ 175k. It has a small rear main seal leak, so I know a clutch will also be needed. If I only plan on driving this on the weekends, how long do you think I can get out of the current one before she blows? What happens when a rear main seal goes? I plan on doing a v8 swap and want to enjoy this for a while. Figuring I could sell this motor to offset the cost for the V8 swap. Any advise is appreciated. Thanks.
hmmm...i would say, till the ol'lady tells you that you're ruining the driveway.
1988 944 turbo |
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Custom User Title
How do you know a clutch will be needed? Based on the miles? When was the clutch last done?
Unless you know for a fact that this is the original clutch, or it's got problems, then you may have years left. You need to inspect the disc and see how much wear is left - Checking Clutch Disc Wear Rear main seals can leak for years - they don't fail catastrophically.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
Automotive Necromancer
pan
I had a large pan i used for weeks before I had to go in for the clutch. In Jag circles we call them kitty boxes. (guess why) If the clutch is solid you can finish the season. Just Keep an eye on the oil. I kept a traveling pan as well so as the car doesn't "mark it's territory" when out and about. You will have to go in there for the clutch soon. You can start collecting parts and get a good price as it is not a rush.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix. |
Redline Racer
The seal itself most likely wont be going anywhere, but it will probably get worse over time. It's a slow painful process, much like the job of replacing it. Use the red Kaco seal, or the Elring seal. Don't waste time with the black seals. It's possible the oil can eventually creep into the clutch and start contaminating it. If the clutch is nearing the end of it's life, you may as well wait, since it all has to come off to replace the seal anyway. If the clutch has more than half it's life left, I would recommend planning a weekend and slogging through it.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Thanks for all the advice. I need to check the clutch wear, but it feels like its starting to slip. Plus Ive heard once a clutch gets oil on it, its time to get a new clutch.
