Radiator fan queston. Simple
When I drive around, and car gets to full temp. I turn her off, and the radiator fans still run till it gets below the 2nd white then turn off.
Is it normal or do i have a bad thermo switch?
Old 02-28-2011, 12:45 PM
it's probly normal. I havent run a stock thermostat and fan switch in forever..
My low temp t-stat kicks on at the first line and the first fan comes on slightly after 1st line and then both fans at 2nd (reg temp) line. and sometimes the fans do stay on after the car is turned off but i have never payed attention to what line it stays on at.
I thin it's normal even new cars with electric fans stay on if the temp gets up
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 02-28-2011, 12:50 PM
I'm pretty sure the fans are supposed to run after you turn it off my car does this; as for the operating temp that depends on your driving if your in lots of traffic or highway cruising that I'm not sure of
Mark S. Certified Porsche Newb
Alea Iacta Est.
1987 924S 67k miles, all stock besides weltmiester Throttle Cam
87 944 Turbo shes got a few goodies. New DD
Old 02-28-2011, 12:52 PM
completely normal to run after shutdown.
remember, the fans run off the thermoswitch in the radiator. completely independent or the coolant temp sw which is in the eng block..two diff temps
do you normally run above the midway mark? If so, that may need investigation.
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 02-28-2011, 08:51 PM
smokin_944's Avatar
Jaime is correct. For example, the driver side fan on an early car stays on with the car shut off til the temp of the coolant reaches the trigger point of the thermal switch. Thermal switches come in different temp values so by changing the Tswitch you can make the fan/fans come on earlier or later.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 03-01-2011, 06:15 AM
Porsche Addicted
bnv944's Avatar
okay this might make me sound stupid, but ive never been sure if this is actually supposed to do this. there is a button one the climate control panel that has the picture of a snowflake on it. i thought (before i had actually drivin or started the car) that it was for airconditioning.
but when i press this snow flake button, it over-rides the fan relay, and gives me control of the cooling fans (unless there already running, in which case if i press the button the fans stay on untill they would regularly turn off, or i press the button again, whichever come last.) is that what its supposed to do, or did a PO rig that?
*1987 944 n/a. project car.
*1989 mazda B2200 beater <-- Update: sent away to be made into IPODS. RIP huebert
*2001 Jeep wrangler SE - THUMPER
"when the wrench starts to turn, but the bolt does not.
The project will take, longer than thought."
Old 03-01-2011, 07:46 AM
Toofah King Bad
Rasta Monsta's Avatar
Normal operation to run the cooling fans while the AC compressor is running.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-01-2011, 07:52 AM
Porsche Addicted
bnv944's Avatar
okay that would explain it, my a/c was f-ed up so i took it out. even when my a/c was still in it wouldnt run which is why tht button confused me.
Old 03-01-2011, 07:55 AM
Redline Racer
HondaDustR's Avatar
(Laughs out loud after remembering old thread)
lets talk cooling pre 85.5
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 03-01-2011, 07:01 PM
AutoX
I have an 88 944 NA and a 91 S2 and the fans run after the car has shut off on both cars.
Old 03-07-2011, 05:39 AM
ernie9944's Avatar
Perfecly normal that they do !!!!
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 03-07-2011, 06:32 AM
