SLED GUITARIST
Dan Himan's Avatar
Oscilloscope
Found on Flea bay. Mini 2.8" 2Msps ARM DSO-201 Nano Pocket Oscilloscope | eBay
Is this adequate for diagnostics on the 944S?
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 03-30-2011, 10:57 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Good luck with understanding the instructions, judging by the advertising blurb.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 03-31-2011, 01:55 AM
Report back if you get one!
John
'88 Rothman Turbo Cup
'91 951S Cabriolet Clone
Old 03-31-2011, 05:49 AM
Proprietoristicly Refined
John_AZ's Avatar
It should work. With instructions.
Here is a "DIY"
Inexpensive Digital Scope...$70 - Rennlist Discussion Forums
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-31-2011, 05:56 AM
All Spooled Up
At 5MHz, it's very narrow-banded, for a scope. My HP/Agilent digitizing scope can display a 1GHz signal (200x), and does 400 Ms/s (200x). But then, it sold for about 200x the what they are asking for the nano-scope. But it is probably 100x the size and weight of a nano, and probably uses about 1000x the power that a nano would use.
Nano-scopes are definitely cool (and the price is exceptionally reasonable), and I plan on getting one at some point. But right now, I holding out for future generations that have better performance specs. The current one would be an excellent choice for someone who doesn't already have a scope though.
Old 03-31-2011, 06:24 AM
Old Guy
sparky4017's Avatar
The only problem i see is this guy has no ebay feedback i can't pronounce his name a 7 day
return policy but 3 to 4 weeks shipping from china if you get one let us know how it works.
1963 Corvette 1969 Z/28 DZ 302 Silver & Black one owner me 1991 Mazda Miata 2011 F250 {work truck] 2011 Sicon
XB LE [Wifes Car] 1983 944 Slant Nose Wide Body [Mine]
Old 03-31-2011, 06:27 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Been thinking about one also for diagnosing things like the ABS system... Let me know how this one works. Given that these cars are 1980s technology (with lots of parts dating back to 1970s technology inherited from the 924 line) the sophistication level of the electronics isn't going to be very high by today's standards, which implies a fairly basic o-scope should work. At least that's how I look at it.
Black Cars Matter
Old 03-31-2011, 07:38 AM
All Spooled Up
I was just looking at this again, and now I see that I made a mistake. The bandwidth of the nano is only 1MHz, NOT 5! So my full-sized scope actually has 1000x the bandwidth of this nano-scope. I've never actually heard of a scope before that wasn't at least a 5 MHz unit. I suppose 1MHz would be enough to catch most signals on these cars, with the exception of signals within the DME, as it runs at 8MHz.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 03-31-2011, 07:46 AM
I am not familiar with this particular piece of equipment, but 1 MHz bandwidth, albeit low, should be OK for any car diagnostic purposes I can think of, as long as we speak of external signals (ignition, injection and so on). It is single channel, which may be a limitation in some cases. If you want to diagnose the internal PCB of the various controllers, you need something else, but that is really another subject alltogether.
I notice the same equipment is also available from dealextreme.com, if you want to go that route. Do read the comments on dealextreme, there seems to be some quality control problems, which the buyers seem to have been able to cope with, but caveat emptor.
Old 03-31-2011, 07:48 AM
SLED GUITARIST
Dan Himan's Avatar
I just want something to check the hallsensor, speedsensor, injectors, etc.
Old 03-31-2011, 08:02 PM
bug bug is offline
bug
On the early cars when you crank the engine the tach should move. If not it is more likely that you may have DME or sensor faults.
Old 04-03-2011, 12:09 AM
SLED GUITARIST
Dan Himan's Avatar
What about a 1987 944S?
Old 04-03-2011, 10:53 AM
All Spooled Up
... and later? I'm sure they do. Ah, go ahead and scratch that. I'm confident enough at this point to say that, I "know" they do. But that only tells you that the crank sensors and the DME (at least in terms of ignition signals) are working properly.
Old 04-04-2011, 03:17 PM
scope
I have one of these- perfectly adequate for poking around on your car.
10MHz Personal Oscilloscope Free Delivery : Oscilloscopes Function Generators : Maplin
Old 04-09-2011, 09:14 AM
