so glad did tensioner !
ok i finish to do tensioner pads this morning only took me 2 hrs slowly and so happy, i had car park for 3 months without starting it, even this morning i was tented to start it but didn't (THANKS GOD) the horror i discovery!!! 89k miles s2
the corner plastic missing i couldn't find it!!, we thought it when tru oil passes , but after finishing i start car noted a clicking noise coming form middle cam were chain is maybe that plastic piece still there ,, I WAS CAREFULLY ENOUGH not to move chain you cna count 7 links in chain what i think is right number ! i will take cover off tomorrow and use flash light and take serious time looking that plastic piece, cause i don't know what else can be
Old 04-10-2011, 03:17 PM
you cna see new tensioner in place and count the links in chain
Old 04-10-2011, 03:22 PM
All Spooled Up
That get rid of the noise?
And what kind of finish is used on those covers? That lower one looks terrible, what would cause that?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 04-10-2011, 03:51 PM
iIuse 500 degree aluminum color dupli-cplor ceramic about 5 coats.. light ones ",, mate color.
The clicking noise come after install new pads and cover ,, I think that little piece of plastic still there some place rubbing sprockets, or near spring or so!!!!, I was carefully not to move much chain So I don't think set it out of timing?? manual said 7 links between marks in cams you can see it in pictures .
Old 04-10-2011, 04:15 PM
All Spooled Up
Not too familiar with the twin-cam heads. But at least the part is plastic, so if it does get jammed up somewhere, it should break up before any damage is done, unless pieces block the oil return holes. If it starts sounding any different, or smoke is observed, shut it right down!
What's the sense in coating the cover, especially if it's going to end up looking like that?
Old 04-10-2011, 04:59 PM
ernie9944's Avatar
Did you replace both bottom & top pads while in there, it's very important to do both at the same time specially if your top pad was broken as shown in the pics the bottom one migth not be to far behind.There something else I don't get ,you said you redone your valve cover,but why is there two off them shown side by side,one seem to be the old one you took off & the other look like it was already done & ready to go????
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 04-10-2011, 05:44 PM
I did both pads, lower wasn't bad but I replace , I got extra valve cover that ia paint 3 weeks ago , to do this project,,,, I afraid of clicking noise! I will unbolt everything tomorrow and look more careful for the piece of pad missing maybe still there making that noise,, other possibility is that lower pads has special orientation cause both ends are not same!i didn't put that much attention to lower pad when i bolt it on, maybe i screw it wrong and now my chain is rubbing metal or something like that can this happen ??
I hope I didn't move timing and destroy a valve or so!!! maybe tomorrow with valve cover off again, manual turn the engine and check the marks in cams and chain and turned and listen for noise!
Old 04-10-2011, 06:01 PM
here is pic actual parts out my car noted the lower pad has ends different , maybe i install it wrong and chain is touching metal in the unprotected corner or so can this happen!!
Old 04-10-2011, 06:04 PM
ernie9944's Avatar
Yes maybe it's wise to remove the valve cover & re-check everything. this migth help DIY - Camshaft chain, tensioner pads - Rennlist Discussion Forums Good luck!!!
Old 04-10-2011, 06:59 PM
your average wrencher...
saved from certain death....nice!
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 04-11-2011, 09:57 AM
Job well done. I had a motor with a terrible metallic grinding noise from the top end. Inspected the cam train and was shocked - no upper pad left at all. Chain had been riding on bare metal and had seriously damaged the tensioner. I'm no metallurgurlist * but guess that this was a long term situation! A few missing cam teeth BUT, thank the gods, no damage that couldn't be put right in a simple bolt in way.
Its good to witness such abuse and the extent in which this "weak link" can cope with criminal neglect and live to fight another day lol
Makes me
Old 04-11-2011, 10:30 AM
Remindes me of when i pulled the plugs when bought the car and found a chunk of the white ceramic part of the plug missing and still has good compression some how :P
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 04-11-2011, 10:32 AM
ernie9944's Avatar
IDO944S2____Are you sure you got 7 links apart on the two cam mark/casting lug .The cam marks has to be in the middle of the marks links (as specify in the RL DIY) if your in & out it could mean a full chain link off,suggest you check that out when removing your valves cover.
Old 04-11-2011, 11:02 AM
I don't see how a regular joe could cock it up? The chain will not stretch one link too tight - you would never get the tensioner back in, too lose then the tensioner would'nt take up the slack? Its been a few months now but i'm sure its fool proof for a TDC initial setting? Dunno, but I always count the links as you describe - seems to fall in place with no margin for error?
Old 04-11-2011, 11:58 AM
